These are all custom transformers, and likely the manufacturer will not tell you the specs.
If you are really sure, these are all dead (which would be a one-in-billion case) and it is some absolutely one-of-a-kind-impossible-to-replace PSU, find someone to unwind, count, rewind. That would be expensive, of course. Make sure, you check every single component, the transformers don't fail for no reason.
Otherwise, buy a new PSU.
