Author Topic: Can anyone supply the values of this cap on a Hayward 2518861-001 driver board  (Read 536 times)
Offline jcrubinTopic starter
    • Technocoma
The cap blew up and took the value with it.... sadly...
Hayward 2518861-001 driver board. Its a board for a Hawward pool pump.
CVM CATAPVLTAE PROSCRIPTAE ERVNT TVM SOLI PROSCRIPTI CATAPVLTAS HABEBVNT
https://www.youtube.com/c/jordanrubin6502
Offline coromonadalix
on theses capacitors you have markings on the top,  do you have some ?
Offline fzabkar
Is the main chip identifiable? Perhaps its datasheet (?) will have an application circuit that will give us a clue.
    • Technocoma
I believe it supports the TNY274-280
https://componentstree.com/wp-content/uploads/2021/09/TNY274PN-IC-Power-Integrations-Off-Line-Switcher-IC.pdf
It maybe a .1 1 or 10uf from the documentation.
