Author Topic: Panasonic Air Con  (Read 932 times)
Offline iwackTopic starter
Panasonic Air Con
« on: September 21, 2019, 09:13:05 am »
Hello,
I have come across a Split Air Con which in heating mode interrupts operation and stops working and in cooling mode the power surges up and down.
The self-diagnosis indicates a H98 error which the Service Manual describes as: "Indoor high pressure protection", "Air circulation short circuit".
Below are photos of the power board. Anybody know which components most likely needing replacement? I'm curious to see if I can find it.
Regards,
Offline Psi
Re: Panasonic Air Con
« Reply #1 on: September 21, 2019, 09:46:56 am »
I could be wrong but it sounds more like a refrigeration hardware/sensor issue than a PCB issue.
« Reply #2 on: September 21, 2019, 10:09:54 am »
I tried warming the power board with hot air blower a couple of times and the problem usually went away.
Offline Electro Detective
« Reply #3 on: September 21, 2019, 10:57:26 am »
It looks to me that some of the soldering in the lower right hand side of the uppermost/top/first photo may have a joint or three with cracks,
which may explain why the 'problem' goes away when hit with a hot air blower = the cracks expand and close up slightly just enough to make contact
Might be worth a closer looksee :-//
