Author Topic: can i recover this battery pins ?  (Read 1092 times)
Offline ammjyTopic starter
  • Country: kr
« on: October 31, 2018, 01:06:44 pm »
Hello !! Thanks you always for kind help !
i have a question about battery pin (please see the photo attached)
cause of not correct size battery. pins now unbalance.
how can i recover this without change component or teardown ??
please give to me advise !
Offline PKTKS
  • Country: br
Re: can i recover this battery pins ?
« Reply #1 on: October 31, 2018, 01:29:02 pm »
You should replace the pin...
otherwise you must fill the space between the minor one
I would try a solder drop on the the battery side ..
small drop or solder blob to fill the space...
long shot...
  • Country: kr
« Reply #2 on: October 31, 2018, 01:32:10 pm »
Thanks you for kind reply, PKTKS.
i have another question.
if, no problem to use - i don't need replace right ?
Offline brabus
« Reply #3 on: October 31, 2018, 04:01:46 pm »
The pins seem fine, I would not touch them.
If the correct battery works, I would do nothing at all.
If you touch them, you risk breaking them; changing the entire connector will be then difficult.
