Author Topic: Can I replace this custom made 2-phase filter inductor with plain thoroids ?  (Read 551 times)
Offline erikbrennTopic starter
  • Country: no
I'm repairing a ventilation system that has a damaged custom made 2-phase mains filter. I contacted the manufacturer and they told me it is a custom job for the ventilation manufacturer, they did not stock it. And the ventilation manufacturer charges an arm and a leg for it.
Each inductor in the original filter is 128uH.
Would it be ok to replace such a filter with two thoroid chokes each of 128uH inductance?  What is the reason they use such a combined filter with the two phases around a iron core instead of just using two chokes?  How does combing two such inductors in one unit change the magnetics/inductance?
Original filter
Considering replacing it with two of these inside a 3d-printed housing.
Online langwadt
Offline fzabkar
128uH seems very low. I would expect that should be millihenries.
Perhaps you could use a 1:1 isolation transformer (with correct phasing)?
https://www.ebay.com.au/itm/353075366503
Offline jdragoset
Since it is EI iron core, Drill rivets, Remove core, Cut Mylar tape, Unwind, Counting turns and direction, Rewind with same size enameled wire and Mylar tape.
The following users thanked this post: amyk
Offline jonpaul
    • IEEE Spectrum
easy to remove clamp, varnish, check gap and wdgs for short/open.
Get same wire, rewind, reassembele
Jon
An Internet Dinosaur...
Offline wasedadoc
Original filter
You need to learn about common mode chokes. You cannot emulate one with two uncoupled windings.
https://www.coilcraft.com/en-us/edu/series/a-guide-to-understanding-common-mode-chokes/
And it is not "2 phase".
« Last Edit: September 03, 2024, 12:44:38 pm by wasedadoc »
  • Country: no
Somewhat late response here, but thanks for the replies.  I dunno what I was thinking, I simply didn't think this was a common mode choke as I have never seen one like this.
The component is faulty, which probably explains its low inductance for its size...  It has burnmarks and is likely shorted
I bit the bullet av ordered a new one for two hundred bucks :)
yes, I realize that now :)
