Author Topic: tektronix TDS 3034B  (Read 394 times)
Offline hitecelecTopic starter
  • Country: in
tektronix TDS 3034B
« on: October 15, 2024, 08:48:47 am »
hello
How does one clean the rotary encoders/switches of the scope
Volts/div, Time/div etc
Thanks in advance
Offline coromonadalix
Re: tektronix TDS 3034B
« Reply #2 on: October 15, 2024, 11:24:51 pm »
i would have used a small twist drill   make 2 small holes,  1 near each plastic post who pass thru the pcb
on the other linked thread you see how the pcb pads are ...  just drill location when the circular pads are not under the square frame
i  first would not decap theses from the pcb,  but try cleanup before anything else
The following users thanked this post: hitecelec
  • Country: in
« Reply #3 on: October 16, 2024, 12:15:02 pm »
hello
thanks for all the inputs
