I probed a bunch of places and got this:
I double checked all the resistor values and they are within a few percent of nominal.
the transformer (t901) provides voltage through D905 provides voltage (about 20-30 volts) for the vertical deflection circuit. it's shown in the schematic snippet, but I don't think it has a bearing on what's happening on the B+ circuit side. I have lifted this diode out of the circuit for testing.
I also do not read any voltage output from this diode. I'm thinking i'm not getting a pulsation in the B+ output (instead just straight DC) which is not allowing the transformer to do tranformer things and produce electricity. (the transformer needing a changing electric current to produce the magnetic field to produce on the secondary)
