Author Topic: Can someone explain why I am missing power on this rail?  (Read 1555 times)
Offline pbrydTopic starter
« on: May 10, 2022, 02:33:09 pm »
Grandstand Firefox F7 wouldn't turn on.
The machine switches on, I get a display and basic sound through one speaker but I am missing in-game sounds through the main speaker.
The missing audio comes from the D1771 chip but I am reading no voltage on the VCC pins 8, 16 on the D1771
I want help understanding what should be happening with the two NPN transistors and the 10 pin transformer.
Having removed the transformer it looks like these pins are connected: 1-7-10 , 2-3-4-5-6, 8-9.
I have added the voltage readings on the transformer when the system is on.
So I'm getting voltage on the tranformer
1: 10.8v
2-3-4-5-6: -30v
7: 0.36mv
8: 6.2v
9: 5.6v
10: 1.2v
Pin 7 isn't outputting anything.
Online coromonadalix
Re: Can someone explain why I am missing power on this rail?
« Reply #1 on: May 10, 2022, 02:56:49 pm »
Normally you search for the parts datasheet when they are available it would help a lot
you have the NEC upd1771 display driver  i think its a vfd display
pin 2 and 6 are the filament  ac voltage
pin7 seems to be the dc ground voltage, it could go to an xformer center tap too
some google search are giving  many links    here's an example
https://www.handheldmuseum.com/forum/viewtopic.php?t=2023&sid=334a8e3609a6bef3aa601a9e442c2add
« Reply #2 on: May 10, 2022, 02:57:27 pm »
Photo of the front of the board
« Reply #3 on: May 10, 2022, 02:59:17 pm »
EDIT   the round 10 pins is an dc-dc converter transformer
with some dmm   you wont be able to read properly the ac voltages due to the working frequency
normally  begin with the electrolytic capacitors, it could damage the dc-dc converter diodes  etc ...
other link,  may need a free registration for the pdf document ??
https://forum.allaboutcircuits.com/threads/grandstand-astro-wars-game-faulty-help-with-component-identification.156824/
« Last Edit: May 10, 2022, 03:01:59 pm by coromonadalix »
« Reply #4 on: May 10, 2022, 03:03:50 pm »
I have a display and the game is running but I'm confused because pins 8 + 16 on the 1771 appear to be on the ground rail.
« Reply #5 on: May 10, 2022, 03:11:39 pm »
UPDATE: checking pins 8 + 16 on the 1771, I do have -5.7v
I still don't understand negative voltage but it looks I should be looking elsewhere for the problem and not the transistors and transformer.
I did come across this PDF earlier, it is from a different game but it does have the same transformer.
On the schematic pin 5 of the XFMR is 0v, so I'm assuming this is what I'm reading.
I took my voltage readings using my oscilloscope (Rigol DS1054z)
« Last Edit: May 10, 2022, 03:28:27 pm by pbryd »
« Reply #6 on: May 10, 2022, 07:02:06 pm »
This is an image from one of the diodes on the board
« Reply #7 on: May 10, 2022, 07:02:49 pm »
It looks very different to the other diode next to it.
Offline CJay
« Reply #8 on: May 10, 2022, 07:38:45 pm »
Simple answer would appear to be that the speaker isn't connected to the audio output.
Audio out is on pin 11 of the uPD1771, if the pinout is correct in this:
https://github.com/mamedev/mame/blob/master/src/devices/sound/upd1771.cpp
Where does the other speaker wire go to?
The following users thanked this post: pbryd
« Reply #9 on: May 10, 2022, 07:59:49 pm »
I have tested for continuity between the speak wires and pins 11 and 13 so that's all good.
Also realised that if I put my meter on the VCC pins and to the positive terminal, I get -5.8v to the chip.
Offline shakalnokturn
« Reply #10 on: May 12, 2022, 11:15:17 pm »
Obviously if they've tied µPD1771C's Vcc to GND they had to make its GND pin negative WRT that. Why and how they went about that though...? Let's hope D1771 tolerates more than 5V supply. Is it warm to the touch?
Attached a portion of schematic with a different revision of the D1771 that should be helpful, pinouts seem to match.
Check what's going on on pins 6 (/PORest?), 9 (CLK IN), 15 (Unknown / Pull-up resistor?), 10 (Unknown), 18-21 (Data bus).
Have you tested the speaker itself is working?
« Reply #11 on: May 15, 2022, 04:02:48 pm »
The game comes with two speakers so I can confirm the speaker is working and I have a direct connection from the audio pins (11, 13) to the speaker itself.
The clock pins 9, 10 show this on my multimeter, so I think they're good.
The chip does get warm to hot yes, I'll look into those other pins too.
Thanks
« Reply #12 on: May 15, 2022, 04:37:17 pm »
I'll assume clock input is OK if you're probing with a 1:1 probe.
« Reply #13 on: May 15, 2022, 05:27:41 pm »
No I have my probe set to 10x.
If I set my probe to 1x, pin 9 6Mhz IN looks flat.
Pin 10 6Mhz OUT still looks ok in 1x tho
« Reply #14 on: May 15, 2022, 05:28:25 pm »
Pin 10 looks ok I think
« Reply #15 on: May 15, 2022, 05:35:30 pm »
Interestingly pins clock pins 9 and 10 are connected via this component.
Offline james_s
« Reply #16 on: May 15, 2022, 05:46:08 pm »
Looks like a 5MHz ceramic resonator.
« Reply #17 on: May 15, 2022, 06:33:27 pm »
Forgive my attempt at drawing this.
