Author Topic: Can someone help identify these caps?  (Read 1755 times)
Offline phlegetonTopic starter
    • spacebugs
Re: Can someone help identify these caps?
« Reply #25 on: August 09, 2024, 07:07:44 pm »
Thanks for this. Maybe a stupid question, how can I measure the voltage. When the drive is in chassis, I can't reach it.
Online fzabkar
« Reply #26 on: August 09, 2024, 07:30:59 pm »
Attach the PCB to the PSU in a desktop PC?
    • spacebugs
« Reply #27 on: August 09, 2024, 07:39:21 pm »
I only have to power up the pcb, and the drive doesn't have to be attached? In that case, I could also use my lab power supply. I have a SATA power cable, I attach picture of it. If I can use that one, that would make things much easier.
Online fzabkar
« Reply #28 on: August 09, 2024, 07:50:12 pm »
Yes, all we're doing is confirming whether the 5V supply is being cleaned up before it gets to the preamp. In fact, just do a continuity check. That should be enough. No need to power up the drive.
    • spacebugs
« Reply #29 on: August 09, 2024, 08:02:57 pm »
I wasn;t sure if the drive needs to be connected for load. I checked, and yes, there is continuity between the +5V and the 5V e-fuse.
Online fzabkar
« Reply #30 on: August 09, 2024, 08:28:24 pm »
I'm wanting to know if there is continuity between the output side of the e-fuse and the HDA connector. That will tell us if the preamp's 5V supply is being protected (and filtered?) by the IC.
    • spacebugs
« Reply #31 on: August 09, 2024, 08:54:52 pm »
Yes, there is continuity between the output side of the e-fuse and the HDA connector.
Online fzabkar
« Reply #32 on: August 09, 2024, 09:02:03 pm »
At this point I don't know any more than anyone else. Your drive has more than the usual protections, so it's hard to see how a bad PSU could be responsible for all those uncorrectable errors. But I'm no expert. :-??
    • spacebugs
« Reply #33 on: August 09, 2024, 09:35:31 pm »
Well, you do know more then anyone I ever met about the electronic part of hard drives. And I'm very thankful for your help and patience. And we can now rule out power supply issues. The question is then.. was this just a fluke? Or the OS which runs on the NAS, had a mind of it's own? Or the SAS controller? When I think about the SAS controller, I start to think about the lanes. That would be very hard to debug, or troubleshoot. I'm not sure if I want to dive into that rabbit hole.
« Last Edit: August 09, 2024, 09:38:07 pm by phlegeton »
Online fzabkar
« Reply #34 on: August 09, 2024, 11:21:21 pm »
When you have a lot of drives in a rack, their mutual vibration can cause tracking problems. However, your PCB has a shock sensor at two corners (the white angled components), so the firmware would have rotational vibration compensation.
https://www.hddoracle.com/viewtopic.php?p=19489#p19489
I really have no explanation for your problems. That said, if you can retrieve a SMART report, then this means that the drives can still reach the firmware zone (System Area) on the platters. In fact, the SMART logs may have more detailed error information. You could use smartctl (Linux) or GSmartControl (Windows) to dump these logs.
« Last Edit: August 09, 2024, 11:24:52 pm by fzabkar »
    • spacebugs
« Reply #35 on: September 19, 2024, 10:54:39 am »
I put everything together, and connected it to my NAS. I decided, not to check for bad blocks on the disk, but just to rebuild the arrays. If something is wrong with the disks, it will show during build. Since this is a Qnap NAS, I had to figure out how to clear the error status on all the disk. As it turns out, the error status is written to a file. By removing the lines which marked the disk as "error" I could restart the whole array build process. Rebuilding the arrays (from scratch) went without any problem. The last step was to write data to the raid arrays, which also went without any problems.
I monitored the disk for a couple of weeks, and everything is running just fine. So why 8 disks failed at the same time, not sure.
To all of you: Thank you for the help, and I also learned a lot. Thanks!!
