Author Topic: Can someone help identify these caps?  (Read 1753 times)
Offline phlegetonTopic starter
    • spacebugs
« on: August 08, 2024, 04:58:18 pm »
I tried to find info about these caps, but I couldn't find any info. I looked for "47 C5N" Which didn't give any result, and I look for "S7 JQ" and "S7 IQ". I could find that "S7" could be 47uF?
What for packages are these caps? Are these Tantaal-polymeer caps?
Hope that someone can help me
Online Grandchuck
Re: Can someone help identify these caps?
« Reply #1 on: August 08, 2024, 05:24:58 pm »
My guess is tantalum
    • spacebugs
« Reply #2 on: August 08, 2024, 05:28:00 pm »
thanks!. Do you know how I can read what values they are? and do you know what package these caps are?
Offline coromonadalix
« Reply #3 on: August 08, 2024, 05:29:33 pm »
yes tantalums
47 would or could be 47 uf, i do think 47 uf        but some web pages say 4.7 uf  used with multipliers ????   for voltages measure between the pins    ex : 12vdc   would be a 16vdc    etc ...
the other ...  searching
would be  from here :  http://www.iequalscdvdt.com/Markings_and_Codes.html
47 uf  indeed
S =4.7
7  is the multiplier    10 exp7
see following answer for more
« Last Edit: August 08, 2024, 05:38:43 pm by coromonadalix »
Offline fzabkar
« Reply #4 on: August 08, 2024, 05:31:13 pm »
Not sure if this is the correct datasheet, but the manufacturer looks like Panasonic:
https://docs.rs-online.com/cd03/0900766b8124ab01.pdf
https://industrial.panasonic.com/cdbs/www-data/pdf/AAA8000/AAA8000COL106.pdf
"S7" is 47uF. If that's a "j" rather than an "l", then the voltage is 6.3V.
 Conductive Polymer Tantalum Solid Capacitors
 Surface Mount Type
 TPE series B size
« Last Edit: August 08, 2024, 05:54:15 pm by fzabkar »
The following users thanked this post: coromonadalix
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: August 08, 2024, 05:37:41 pm »
See also https://www.jauch.com/downloadfile/58afeb6aded9b_11cb0b44f8a2e66625ae/ntpg.pdf
The "47 C5N" might be voltage code 'C' (16V).  47uF seems reasonable for the size.
I don't think there's a clear / universally followed body or color rule regarding chip electrolytics; they could be tantalum (MnO2 or polymer), or aluminum polymer.  I think the latter are uncommon or absent in these exact styles, but various chip versions do exist.  (Aluminum are generally more common in "can" formats, but are not exclusive.  Aluminum electrolytic I think are always can.)  In any case, they are likely tantalum something or other.
Seven Transistor Labs, LLC
    • spacebugs
« Reply #6 on: August 09, 2024, 11:36:53 am »
Thanks all for the information! I de-soldered two of the caps from the board, and the both measure 50uF. So that means that they are  both 47uF. I tried to find on which voltage rails the caps are attached to, but I only could find that the smaller cap is attached to the 5V rail.
(some background: This board is a backplane of a QNAP REXP-1620U-RP. A 16 bay disk drive expansion unit. Suddenly all the low 8 disk drives failed. So my first idea was, maybe there are some bad caps, which could cause a voltage rail to misbehave (have seen that before). Measuring the voltage on the backplane, is very had, if impossible at all, since a fan is in the way, and I don't want to run the chassis without fan, which could the control/motherboard to overheat. And even without fan, it's hard to get to measure.
Online janoc
« Reply #7 on: August 09, 2024, 11:56:08 am »
So you are trying to randomly replace tantalum capacitors??? STOP!!!
Tantalum caps fail rarely and when they do, it is usually with a bang and fire. Those are not the usual electrolytic caps in power supplies that dry out or leak and have high ESR over time, causing problems!
You need to find a way how to measure the voltages before you attempt any repair. That is the first step to diagnosing the problem. Only then it makes sense to even start thinking about how to fix it.
Replacing parts at random is useless - esp. given that there are probably few hundreds of various decoupling capacitors - and any of them could be shorting a rail, for example. Or you spend a week replacing all of them, at a large expense - only to discover that it didn't fix anything because the problem was something else, such as broken wire, dodgy contact,blown FET in some supply, etc. And in the process you have likely also lifted some tracks and damaged the board.  Moreover, that is only one possible issue - the drives could be failing for other reasons too - maybe one channel of the disk controller has failed?
« Last Edit: August 09, 2024, 12:00:26 pm by janoc »
    • spacebugs
« Reply #8 on: August 09, 2024, 12:48:31 pm »
I don't like to randomly replace capacitors. So I try yo find out if they are tantalum caps, or if the are a polymer type. And I would like to measure voltages, but that is almost impossible. I tried to figure out how the power rails are layout, and how it is all connected. But with a multilayer board, where not all traces are visible, and with no schematics, it's almost impossible (And I don't have the time to spend weeks on it to fix it).
I have a years of experience with storage. And I know that drives can fail in the most strange ways, and unexpectedly. But 8 drives, which all fails at once is possible but unlikely. There is one scenario that I can think of, and that one drive has developed some kind of short on it's power rail, and caused other drives to fail. But if that happened, why not all 16 drives ? (and I didn't find that drive yet, and with the chassis now taken apart, it's not possible either to test the drives further for now |O).
To make it more interesting,  I let a drive scan for bad blocks (just before I took the chassis apart), and that ended without issues. Of course, it's not the same load if I tried to scan all 8 drives at once. The problem seems to be intermittent, or it's with a certain load.
In this case a pragmatic approach could be to replace the caps, if the cost aren't to high, then at least I (hopefully) eliminated one possible cause. Or I could replace the caps on one port, and see if that changes behaviour. Again, without schematics, and the intermittent behaviour this is impossible (at least for me). But if I can save this from ending as e-waste, I'll try.
Offline fzabkar
« Reply #9 on: August 09, 2024, 03:53:10 pm »
That makes no sense. The failure of one drive cannot be responsible for the failure of others. The only plausible reason for multiple failures is a failure in the common power supply which has then overvolted your HDD array. If this is the problem, then it will be easy to prove. Just examine and test the protection components on each drive. These typically consist of TVS diodes for each of the 5V and 12V rails, and/or smt fuses or e-fuses.
TVS Diode FAQ:
http://www.hddoracle.com/viewtopic.php?f=100&t=86
PCB protection devices:
https://www.hddoracle.com/viewtopic.php?f=100&t=1615
    • spacebugs
« Reply #10 on: August 09, 2024, 04:04:57 pm »
Okay thanks for the informative articles! So that scenario is not possible and can take it of the list :-)
Offline fzabkar
« Reply #11 on: August 09, 2024, 04:16:17 pm »
If a drive doesn't spin up, I can help you to narrow down the fault. Just upload a photo of the PCB. Otherwise, here is another tutorial:
HDD / SSD power supplies:
https://www.hddoracle.com/viewtopic.php?f=59&t=231
    • spacebugs
« Reply #12 on: August 09, 2024, 04:19:30 pm »
I still have to test all the failed drives. But when the drives failed, they were all spinning. But if a drives fails to spin, I now know where to look for. So thx again!
Offline fzabkar
« Reply #13 on: August 09, 2024, 04:27:04 pm »
If they're spinning but cannot be detected, that's usually an internal fault. Typically it's a bad head or a damaged firmware module, or both. It's not something that would occur simultaneously on multiple drives. It could be that you have a RAID which was running in a degraded state and only became noticeable when the last drive failed.
    • spacebugs
« Reply #14 on: August 09, 2024, 04:36:48 pm »
What happened is that suddenly 8 drives in a RAID6 array failed (slots 1,2,3,4,5,6,7,8) While these 8 drives failed, the other 8 drives in the another RAID6 array (but in the same storage pool) just kept working. (of course the storage pool itself was not) The 8 drives failed with a unrecoverable error. But the drives where still spinning, and I could look at the S.M.A.R.T status etc.
*edit* Both the arrays were healthy before the drives failed.
« Last Edit: August 09, 2024, 04:39:16 pm by phlegeton »
Offline fzabkar
« Reply #15 on: August 09, 2024, 04:43:54 pm »
It sounds like degraded heads. I suspect that these drives are Seagates.
    • spacebugs
« Reply #16 on: August 09, 2024, 04:46:17 pm »
How likely is it that the heads fail at the same time? But the disks in question are: HGST Ultrastar He10 10TB SATA
Offline fzabkar
« Reply #17 on: August 09, 2024, 04:53:01 pm »
HGST is considered to be the most reliable brand at this time. I can't explain your failures. Very strange.
« Reply #18 on: August 09, 2024, 05:06:46 pm »
yep  Seagate died on me many times, some FW updates where issued,  but doing so  made you lost all the content  :palm:
unless you had some power spikes, or some controller failures, it's kinda hard to explain ?   data corruption ??  virus ?
    • spacebugs
« Reply #19 on: August 09, 2024, 05:44:57 pm »
I can't explain it either. It's not something I've seen before that so many drive fails at once. I have witnessed several times, that during a rebuild of an array another drive failing, being caused by the heavy operations on the drive during rebuild (depend in the type of array that is).
A virus seems unlikely. Data corruption, depends on what data corruption. If a drive is faulty due to bad blocks for example, then it's like fzabkar already pointed out: The array will be in degraded mode. Sure.. in a RAID 6 array, when more then 2 drives fail, the whole array fails (However the remaining disks itself should still be ok). In this case, the storage pools are used for storing backups. So if a a file is corrupted, and is written to disk, that won't harm the disk itself (but the question is then: how got the file corrupted in the first place?)
Spike on a voltage rail, or a dip in the voltage rail, that could cause some strange behaviour. But what I now understand from fzabkar, is that this is not so easy, since components prevent at least at disk level. But what happens if a voltage rails has a large dip, or the voltage rail is very noisy. That has then to be on the main voltage rail I guess. That could be the power supplies. In this case, the power supply are redundant. And if there is a something wrong with those, I expect to see a alert, that a power supply failed (or both) in which case, the cause will be very obvious.
Offline fzabkar
« Reply #20 on: August 09, 2024, 06:07:05 pm »
The preamp on the headstack needs two supply voltages. Typically these were +5V and -5V. The former was derived directly form the 5V input, usually via a low pass LC filter. I don't know if the newer HGST drives down-regulate the +5V supply. If not, they would be exposed to any noise or dips on this rail.
    • spacebugs
« Reply #21 on: August 09, 2024, 06:11:47 pm »
That is interesting, is that easy to determine?
Offline fzabkar
« Reply #22 on: August 09, 2024, 06:18:58 pm »
Yes. Remove the PCB, upload a photo, and I'll show you where to test.
    • spacebugs
« Reply #23 on: August 09, 2024, 06:31:48 pm »
See attached photo. Hope it's sharp enough.
Offline fzabkar
« Reply #24 on: August 09, 2024, 06:59:59 pm »
Your PCB has two stages of protection. The first level has two TVS diodes and two smt fuses. The second level has an IC that incorporates a Vcore regulator plus 5V and 12V e-fuses.
https://www.hddoracle.com/viewtopic.php?p=22339#p22339
I have marked what I think are the preamp supply test points on the HDA connector. Measure those voltages. I suspect that the negative supply will be -3V. If the positive supply is +5V, then power down and test for continuity with the 5V pins at the SATA power connector, and the +5V e-fuse.
