Hi Andy Watson,
Yes I have a schematic.
http://www.tangible-technology.com/schematics/fender/HR-Deville/Hot Rod DeVille.pdf
The tubes are matched and checked with my Navy TV-10 and also I installed another set just to check...so I don't think this is a tube issue. Also changed several of the 12AX&'s just because. I have seen some truly strange stuff with tubes..lol
Thanks for all the feedback.
1. My radar has been going off about the out put transformer...not sure why just a guess. The coil reads 111.47 ohms on the primary, from one side to the center tap is 58.45 ohms and from the other side to the center tap is 53.83. Also there is no short to the secondary from the primary on the op trans. I have no idea what the correct readings should be.
The one major issue that I do not understand is the overheating issue and what could cause it. The 6l6 out put tubes run at normal temps, volts, milli amps, bias voltage at idle. As soon as I inject a 1000 hz signal at 100 mA into the first pre amp tube the out put tube start to heat up and I have shut down the amp when they get over 420 F as 450 F is the limit per the data sheet.
Something else I do not understand...ON the schematic Test Point 24 says 14.7 V...does that mean AC voltage?? That point is the plate of V3A which connects to the Y DC voltage of 441 V...well there is a 82k resistor between the y voltage and the plate
I think I will post some fishing photos...much more fun...lolhttps://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg
What I am really trying to figure out is what voltage is causing the 6l6 tubes to heat up...We know the plate voltage is ok. We know the idle current is OK. we know the bias OK. So...
Gona check out put jack next.
I been at this for a while so a cup of coffee is in order. I also quit smoking about a week ago. The good news is I have not kicked the dog or the wife ...yet...lol Well...the night is young...lol
