Totally agree. It is the OP’s desire to learn from this investigation or repair that prompted my comments to help him. As a commercial repair the unit is definitely scrap as it is beyond economic repair in man hours alone, let alone any modifications required to improve reliability. As others have said, a replacement, better designed power amp module or even a complete new sub woofer unit would likely be a better course to follow if the OP was not keen to learn from this units repair. That said, I have taken on repairs for friends in the past and bitterly regretted it after spending many hours sorting out a real sticker of a design that belonged in the bin ! I learnt from those experiences though
I think the worse was a friends Trio Kenwood TS9xx (TS940?) base transceiver...... lots of failed capacitors and more dry joints than I have ever seen in a unit previously. If you moved any PCB you were likely to cause more failed solder joints. I found out that the particular model was infamous for such failures and was basically a rabbit hole you did not want to enter ! It took me two months of evenings working on it when I had the time and motivation before it was repaired and relatively reliable. I honestly lost count of the solder joints I desoldered, cleaned and resoldered. It was in the hundreds of joints for sure
I gave it back to the friend and told him that I never wanted to see it again and he should sell it while it still worked ! Why did I not give up on the unit as beyond repair ? Well I should have done but he was a good friend and I hate to be beaten. If I had my time again, I would have stopped work on the unit after a week of chasing multiple dry joints and failed capacitors on many PCB’s. The unit is just not worth the effort, even when repaired ! A good lesson learnt though. Did I charge for the work.... nope, I used to repair equipment for free as I liked the challenge and learned a lot along the way.
