Hello troops-
I'm hoping you can look over my shoulder on a repair I'm working on. It is being very stubborn. It's an old Kenwood quadraphonic(!) receiver, model KR-8840. I could really use a sanity check.
FAILURE PATTERN:All 4 channels work and pass signal but all 4 channels have an obvious hum. The hum seems equal in all channels, which implies a single common failure. I've measured about 100mvAC at the speaker terminals, and my meters say the frequency of this is 120HZ, which makes me instantly suspect a power supply problem (as opposed to a bad ground somewhere where you would reasonably expect 60Hz) . But measuring all the supplies suggests they're OK ripple-wise.
The hum is not affected at all by the volume or balance or tone controls. When using an external source into the AUX inputs the volume and balance controls work normally, suggesting they are not missing the ground connection at the bottom of the resistive elements. Signal volume can be adjusted to zero routinely. This suggests the problem is after the volume control.
The only front panel control that changes the hum is the lo filter S4; engaging this reduces the hum level. This suggests the hum is in the signal at that point in the path. So I must be in the right neighborhood, right? Afraid not, read on.
STEPS TAKEN:On the 'main amp' board I removed all 4 input capacitors and it fell dead silent, no hum (& no signal, obviously). This suggests the power amps are OK & the rails that feed the power amp are clean.
Just upstream of the main amp board is the '20dB amp' board. This is where the loudness, lo filter, and hi filter controls reside. The output of this stage directly feeds the main amp stage. The input of this stage is fed directly from the volume control. Remember the volume control does not affect the hum at all. So the problem must be after the volume control and before the main amp, right? It must be on this 20dB amp board, right? Wrong.
Looking at the 20dB amp schematic I have replaced the 47uF rail filter (even thought ripple measured OK); no change in symptoms. Also I randomly chose the channel I had best physical access to and removed the output cap C22 - hum stopped in that channel. I replaced it (with new) and then removed input cap C18 - hum stopped in that channel. I replaced C18 with new; hum still the same. This implies the problem is before C18 but after volume - and there's basically nothing there. S5, the loudness control, does not change the hum.
Even though it's counter-intuitive I tested to see if the hum was arriving at the high side of the volume control. This is directly fed from 2 two channel 'tone control boards'. I went there and measured input pins 1&2 and output pins 3&4 with no signal. All were about 1mV both AC & DC. Seems fine, right? So I shorted the output pins 3&4 to chassis using a clip lead. The hum didn't change, which suggests the problem is after the tone boards.
SUMMARY:Testing suggests the hum is getting into the path after the tone board & volume control. It also suggests the problem is BEFORE the 20dB amp (remember yanking C18 stopped it dead). This is one of those "both things can't be true" moments.
I have to conclude this schematic does not exactly match my unit in this area. Unfortunately this means I have to disassemble the entire front panel to investigate further, and that is a damn mechanical nightmare that I'm trying to avoid. It looks like hours of work. So before I dive in I wanted to see if you had any other ideas?
Thanks, as usual, for casting expert eyes on this.
I can't post the full schematic as it's over 8 megs but it's available online in a few different places. I got it from hifiengine.com... which, if you somehow don't know, is a wonderful (and free) resource. Link to schematic is below. But here are some cut-n-pastes of the pertinent areas. Thanks again.
https://www.hifiengine.com/manual_library/kenwood/kr-8840.shtml
