Author Topic: Can you identify this connector?  (Read 878 times)
Offline HogwildTopic starter
« on: July 18, 2021, 11:28:40 pm »
Hi:
So I decided to replace the cooling fan in my LTO-2 tape drive.
On opening it, I noticed this connector attached to the PSU
which then mates with another connector attached to the
cooling fan. Can anyone tell me the name of this connector
so I can buy its mate?
Offline bob91343
Re: Can you identify this connector?
« Reply #1 on: July 18, 2021, 11:36:31 pm »
Maybe a Molex?
Offline ataradov
    • Personal site
« Reply #2 on: July 19, 2021, 12:38:52 am »
This looks like Molex Microfit. There a few variants with different sizes, but it should be easy to find by that name.
I think this is your connector: https://www.mouser.com/new/molex/molex-micro-fit-tpa-connectors/
Alex
« Reply #3 on: July 19, 2021, 12:54:42 am »
Thank you very much. That's so helpful.
Finally, I'll be able to do tape backups without
the deafening noise.
« Reply #4 on: July 19, 2021, 01:51:33 am »
How do you fasten that connector to the wires?
Is it crimped on? Soldered on ?
Online coromonadalix
« Reply #5 on: July 19, 2021, 02:12:04 am »
Seems to be the same found on atx psu's
Crimped pins
Offline PeteH
« Reply #6 on: July 19, 2021, 02:15:55 am »
That could be a mini fit JR miles series.  Check the pin pitch (3mm vs 4.2mm).
Crimp tools are expensive, you could just buy the board mount option and solder wires onto the pins (or solder wires onto the crimps)... Depends on the gender.
« Reply #7 on: July 19, 2021, 03:15:14 am »
Ah, thank you. Looks like it's time to call Digikey.
Offline ataradov
    • Personal site
« Reply #8 on: July 19, 2021, 03:23:15 am »
You can solder it too in a pinch. It is not designed for it, but it works if you only need a few.
Alex
« Reply #9 on: July 19, 2021, 03:25:31 am »
How do I check the pin pitch? I don't even know that pin pitch is.
I have limited tools as I don't repair electronics.
Offline ataradov
    • Personal site
« Reply #10 on: July 19, 2021, 03:29:54 am »
Measure approximate distance between the pins. And overall connector size.
Alex
