Author Topic: Can you identify this connector  (Read 828 times)
Offline VamanTopic starter
« on: January 21, 2023, 01:21:46 pm »
I purchased a Mini Circuits ZX76-31A-PPS+ off Ebay and I am trying to source the 10 way control connector. Mouser etc want £35.00 for a 1.5mtr cable, which is more than paid for the attenuator. I have seen the connector sometime ago but do not know what it is called in order to trace it.
« Last Edit: January 21, 2023, 07:52:32 pm by Vaman »
Offline madires
  • A qualified hobbyist ;)
Re: Can you identify this connector
« Reply #1 on: January 21, 2023, 03:16:40 pm »
The datasheet clearly notes that the connector is an SMA. Don't confuse it with RP-SMA, which is the standard connector for WiFi antennas.
Re: Can you identify this connector -SOLVED see under Ham radio
« Reply #2 on: January 21, 2023, 03:27:35 pm »
Apologies I did not make myself clear. Yes  the unit is SMA, it is the 10 way connector for the control lines that I am trying to identify as per the attachment.
« Last Edit: January 23, 2023, 05:02:10 pm by Vaman »
Offline tooki
« Reply #3 on: January 25, 2023, 08:22:55 pm »
£35 is probably less than the value of the amount of time needed to track down the connector, never mind assemble it…
Offline coromonadalix
« Reply #4 on: January 26, 2023, 12:40:20 am »
Is it me or this look like an E-Sata connector ???
Offline Momchilo
« Reply #5 on: January 26, 2023, 02:31:29 am »
You can buy the cable from Ebay a little bit cheaper: https://www.ebay.de/itm/141848090347
But looks like some sort of a Sata connector.
Offline DavidKo
  • Country: cz
« Reply #6 on: January 26, 2023, 06:10:48 am »
E-Sata have different locking mechanism. This one seems to have also different height/width ratio.
« Reply #7 on: January 26, 2023, 07:38:00 am »
Thanks all for your input folks.
The connector is now identified as an HRS connector that Mouser etc sell for around £2.50. It was identified by the owner of a Mini Circuits ZX76-31A-PPS+ .So my next order will include on of those.
The following users thanked this post: madires
