Author Topic: Can you please help to identify this smd fuse?  (Read 1470 times)
Offline tlhsglmTopic starter
« on: July 07, 2022, 12:08:16 pm »
Hi all,
I have to identify this boards components. It is a step motor controller. I stuck on that fuse( I think it is fuse by looking the letter F2).
It has no marking letters on it. Solders not included dimensions are 3 mm x 1,5 mm.
Can you please give me an idea or track?
I think it is working and i will desolder it later but when i done i dont know how to identfy it.
https://ibb.co/jRT1JNQ
https://ibb.co/BtK7pv0
https://ibb.co/8gq6pF3
« Last Edit: July 07, 2022, 12:10:17 pm by tlhsglm »
Offline abdulbadii
Re: Can you please help to identify this smd fuse?
« Reply #1 on: July 07, 2022, 02:01:32 pm »
try see ahead for max Amp I for Q/D/IC property then match it on https://www.mouser.com/pdfdocs/teconnectivitysurfacemountfuses.pdf
« Reply #2 on: July 07, 2022, 09:41:40 pm »
Thanks for your reply but kindly i didn't understand "try see ahead for max Amp I for Q/D/IC property" how can i check it?
Extra info: I tracked package dimensions it's lenght 3mm width 1.5 mm and height is 0.60 mm . Most packages does not matching height.
Offline Wallace Gasiewicz
« Reply #3 on: July 07, 2022, 11:28:13 pm »
He means try to estimate the amps of the fuse considering what is supplies...Does it supply the motor??? ....then see what amps the motor draws...something like that.
« Reply #4 on: July 08, 2022, 07:53:04 am »
Thanks for your reply, oh i get it. Also i have to check it's type with oscilloscope right? To understand is it a general fuse or resettable fuse?
« Reply #5 on: July 08, 2022, 04:13:14 pm »
Check it for continuity with an Ohmeter. It is not a resetable
If reads very high in the circuit, it is blown.
You have to estimate the amperage rating of the new fuse you will install.
« Reply #6 on: July 09, 2022, 02:45:52 pm »
Okey it is not blown.
To estimate amperage rating, I'll see what part it connects to. Then I will look at its datasheet and choose the maximum amperage value, right?
« Reply #7 on: July 09, 2022, 06:16:27 pm »
Why replace the fuse if it is not blown???
« Reply #8 on: July 10, 2022, 08:03:37 am »
Because i want to learn everything in the card and how it is works. It is a card for step motors. I think it will be very beneficial for me to learn and interpret the card of a machine used in the industry in this way.
Online tooki
« Reply #9 on: July 10, 2022, 12:30:00 pm »
A fuse is a protection device, nothing more. To an extent, it doesn’t exist as part of the circuit. Its purpose is as a controlled point of failure if something goes wrong elsewhere.
It being unmarked, there’s no way to know what its precise characteristics are. Even destructive testing wouldn’t let you identify it conclusively.
I think you’d be better off learning about fuses independently of this, and for the purposes of this circuit, just pretend it’s not there.
The following users thanked this post: tlhsglm
