Author Topic: Cannot find smd number  (Read 698 times)
Offline keifcoofghookTopic starter
« on: January 07, 2025, 12:59:18 pm »
i have this smd that i need to replace: c8csa | sot-23
can anyone help?
Offline Swake
Re: Cannot find smd number
« Reply #1 on: January 08, 2025, 01:37:47 pm »
Not conclusive but nevertheless herewith what I found.
Everything is SOT23
Marking
C8           BCF30 - Transistor
8C           MMBZ5228B - 3.9V zener 0.225W
8S           MMBZ5242B - 12V zener 0.225W
SA           BSS123 - n-ch mosfet 100V 0.17A
nothing found with
08
O8
8SA
Could not find what the C with double underline means, did not find a similar logo either.
Well, it must be out there. If you find something let us know !
When it fits stop using the hammer
Offline inse
« Reply #2 on: January 08, 2025, 01:49:48 pm »
What does U indicate in your PCB? IC, Transistor, MOSFET?
If you don’t know what it is, how do you know it needs replacement?
Draw a schematic around this part, maybe it gets clearer…
« Reply #3 on: January 08, 2025, 02:30:01 pm »
i know it needs to be replaced just by the look of it and based on the marking, u71 seems to be same as u70 because of the order of the other components and i also checked the bad smd under microscope and i saw the first 2 letter c8.
Offline inse
« Reply #4 on: January 08, 2025, 02:36:16 pm »
Then desolder U71 and measure what it is, would help searching
« Last Edit: January 08, 2025, 02:48:48 pm by inse »
Online wraper
  • Country: lv
« Reply #5 on: January 08, 2025, 02:38:04 pm »
Dunno why they're designated as Uxx but they are N-channel MOSFETs.
Online wraper
  • Country: lv
« Reply #7 on: January 08, 2025, 08:51:15 pm »
this is c8kda and its similar but how can i find thh exact one.
thanks for the help by the way
Online wraper
  • Country: lv
« Reply #8 on: January 08, 2025, 09:03:54 pm »
You won't ever find exactly the same code unless it's a part from the same batch. Device code is c8, the rest has nothing to do with part number.
« Last Edit: January 08, 2025, 09:07:48 pm by wraper »
The following users thanked this post: keifcoofghook
