Author Topic: Can't decode resistance value with color code - help!  (Read 542 times)
Offline jrlemieuxTopic starter
« on: November 01, 2024, 01:04:15 am »
Hello !
I am trying to decode the resistance value for the R1 part on a PCB-0046, Electrolux 3164627 pcb 0046, es52x_36x PCB.
Many people say it is a 221 ohms, but I am unable to confirm this value, as the colors on the resistance do not seem to be compatible with the 5 band color codes.
The various pictures of the resistors were captured on the Internet, sorry if they are fuzzy.
Is anyone able to decode the resistor value with certainty?
Thanks !
JL
Offline themadhippy
Re: Can't decode resistance value with color code - help!
« Reply #1 on: November 01, 2024, 01:22:26 am »
does this help?
All 5 band resistors with the 4th band of silver or gold form an exception and are utilized on specific or older resistors. The first two bands represent the significant digits, the 3rd band is a multiplication factor, the 4th band is for tolerance, and the 5th band is for the temperature coefficient (ppm/K).
The following users thanked this post: jrlemieux
Online Analog Kid
« Reply #2 on: November 01, 2024, 01:38:37 am »
220Ω, not 221 (red-red-brown). Almost the same difference, but still.
« Reply #3 on: November 01, 2024, 03:11:37 am »
I found that the 5th white band indicates that the resistor is a "fusible resistor".
So it really is a 220-ish ohms resistor.
Thanks
Offline Greybeard
