Author Topic: HP 1727A scope revisited; vertical amplifier problems.  (Read 3397 times)
Offline Alex_BakerTopic starter
Re: HP 1727A scope revisited; vertical amplifier problems.
« Reply #25 on: March 04, 2022, 11:42:17 pm »
Thanks, don't know how my search didn't find that.
Offline CaptDon
  • Country: is
« Reply #26 on: March 04, 2022, 11:42:55 pm »
Looking at the trace you have zero crossing distortion which indicates generally not enough bias on the deflection transistors so they only conduct in areas above the zero crossing area. I know you have done some troubleshooting. I would be looking at resistors that have gone up in value and often in the deflection circuits that resemble comp/sym you have to check everything 'out of circuit' and look for shifts like an 18K measuring 22K out of circuit. I have seen that and been fooled by 'in circuit' measurements where the values look spot on!!
« Reply #27 on: March 05, 2022, 11:47:54 pm »
Thanks for the info, however on a different HP/Agilent specific site we did some troubleshooting that showed that U2 is bad, resistance measurements between pins of an otherwise symmetrical IC are not symmetrical.
Offline guneszop
  • Country: aq
« Reply #28 on: March 15, 2022, 09:41:36 am »
I think the next thing to do is check the voltages on U1 as appearing on the schematic techzpod.com mobdro apk
« Last Edit: March 16, 2022, 08:30:27 am by guneszop »
« Reply #29 on: March 15, 2022, 03:09:25 pm »
Please review previous posts.
