Author Topic: Can't find low-ESR cap - alternative solution?  (Read 6983 times)
Offline sb1370Topic starter
  • Country: ir
« on: October 16, 2020, 10:02:47 pm »
Hi
I'm repairing my monitor power board and I found two blown capacitors which are from low ESR series. I could find a replacement for 680uf 25v cap which is 50v and have to fit it someway. But my problem is I couldn't find a replacement for 1000uf 25v with low ESR.
I thought about using two 470uf in parallel to reduce ESR but according to the ESR formula it won't work cause by halving capacity the ESR doubles (in theory).
I know I can order from the internet shops but the shipping costs outweighs the capacitor price and won't worth it.
What's your suggestions? Also is it a right thing to not touching the other caps cause as I said I can't find the proper replacement.
« Last Edit: October 16, 2020, 10:29:02 pm by sb1370 »
Offline ogden
  • Country: lv
Re: Can't find low-ESR cap - alternative solution?
« Reply #1 on: October 16, 2020, 10:09:14 pm »
There is no such manufacturer part number "capacitor which is from low ESR series". Please be specific - what exactly capacitors you are talking about. I doubt that low ESR is key property in your case. Put new generic capacitors in and most likely you will be fine.
« Last Edit: October 16, 2020, 10:12:11 pm by ogden »
  • Country: ir
« Reply #2 on: October 16, 2020, 10:26:08 pm »
What? I have seen many of them. BTW it's GF series of Samxon.
Offline wraper
  • Country: lv
« Reply #3 on: October 16, 2020, 10:38:31 pm »
470uF capacitor will have higher ESR than 1000uf from the same series, however when you connect 2 capacitors in parallel, ESR basically halves. So two 470uF caps instead of one 1000uF is a viable solution. Or if those two 1000uF caps are in parallel, better use three 680uF capacitors instead.
« Last Edit: October 16, 2020, 10:40:14 pm by wraper »
Offline precaud
    • LinearZ
« Reply #4 on: October 17, 2020, 02:05:18 am »
All of the 1000uf 25v radial polar 'lytics of current manufacture I've measured recently have pretty low ESR, in the 15 to 25 mOhm range. To get one that isn't, you'd have to buy the cheapest junk available, or a series that is made to a higher-ESR spec, such as Nichicon PM series.
Offline wraper
  • Country: lv
« Reply #5 on: October 17, 2020, 02:18:58 am »
It's not so much about ESR as such but that general purpose capacitors will not survive there for more than a few months due to high ripple current.
Offline precaud
    • LinearZ
« Reply #6 on: October 17, 2020, 03:37:11 am »
Perhaps, but that's not his question.
Offline wraper
  • Country: lv
« Reply #7 on: October 17, 2020, 04:05:15 am »
His question is about suitable replacement. General purpose capacitors are certainly not suitable to be there.
Offline precaud
    • LinearZ
« Reply #8 on: October 17, 2020, 04:12:22 am »
Where is "there"? He hasn't said where in the circuit they are. If they're post-regulator, ripple current will be negligible.
Offline wraper
  • Country: lv
« Reply #9 on: October 17, 2020, 04:14:46 am »
Here there:
Capacitors on secondary side of SMPS/power input of CCFL inverter.
  • Country: ir
« Reply #10 on: October 17, 2020, 07:25:21 am »
Have you tried it in practice? because in theory ESR=tan δ / (C*f*2π) says otherwise. Unfortunately I don't have a ESR meter to measure it.
Well you are right the DF between general purpose and Low-impedance/ESR series isn't much different so in theory their ESR shouldn't be much different I can even get higher voltage ones for lower ESR, but I don't know how they are in practice. I think the more important factor here is "Ripple Current". Ripple current of a low-impedance series is twice the general one with the same ratings.
I agree with you, however I looked up the power board of another monitor newer but close to my model from the same brand and there they likely had used regular capacitors.
Offline ogden
  • Country: lv
« Reply #11 on: October 17, 2020, 07:48:20 am »
It is very much about low ESR and high ripple current - combined. Low ESR capacitor will heat-up less, thus live longer. My consideration of suggesting generic (105oC) cap - most monitors do not consume much, thus ripple current may be tolerable for generic to live some 5 years or longer. There's always option to replace capacitor again ;)
I would not even consider putting multiple capacitors where is place for only one. What's the point of adding low ESR capacitors through long, inductive leads which have higher ESR/impedance than generic caps?  |O
« Last Edit: October 17, 2020, 07:52:53 am by ogden »
Offline mzzj
« Reply #12 on: October 17, 2020, 09:12:47 am »
Answer to "where?" is "Iran" and it might explain if OP has problems sourcing any components.
Offline precaud
    • LinearZ
« Reply #13 on: October 17, 2020, 01:28:51 pm »
Good point...
Some cap makers list ripple current rating as a function of case size. So, if there's an absence of detailed info, the OP could put the largest cap he can find that will fit in there. Voltage rating can be higher than 25V, of course.
Offline wraper
  • Country: lv
« Reply #14 on: October 17, 2020, 01:33:51 pm »
I've never seen LCD monitor with general purpose capacitors in PSU on 12V+ rail. And overall they are almost nonexistent in SMPS, sometimes placed on some power rail with low current, while the rest use LOW ESR.
Offline wraper
  • Country: lv
« Reply #15 on: October 17, 2020, 01:36:30 pm »
Even some LOW ESR caps do not survive there for long. General purpose caps will pop very fast, hopefully without electrolyte spraying over the board. If OP can get 470uF LOW ESR, using general purpose capacitors is dumb.
The point is they will not fail. Longer leads will make no noticeable difference.
« Last Edit: October 17, 2020, 01:38:17 pm by wraper »
Offline ogden
  • Country: lv
« Reply #16 on: October 17, 2020, 01:58:44 pm »
Yes. - It will work when one of two capacitors is right where 1000uF needs to be and other is doing low freq bulk storage work.
Hold your horses. Extra length of capacitor leads will increase impedance at high frequencies, thus increase ripple amplitude on the PSU output. It's SMPS design basics - do not use extension cords for your filtering capacitors :D
Offline wraper
  • Country: lv
« Reply #17 on: October 17, 2020, 02:04:25 pm »
Then look at length of traces on those one layer PCBs. Also it's not like there are super high frequencies.
Offline ogden
  • Country: lv
« Reply #18 on: October 17, 2020, 02:26:50 pm »
Look where exactly? Filtering capacitor connected to power rail through "length of traces"? Could you please show what you are talking about?  :-//
Broadband noise of SMPS easily reach 20MHz. Inductance of 1cm long 0.5mm dia conductor is 7nH, impedance of such @10MHz equals 0.4Ohms. Take a moment to consume this.
Offline wraper
  • Country: lv
« Reply #19 on: October 17, 2020, 03:01:50 pm »
Take a moment to consume there is easily 4-5 cm or more trace length from transformer to capacitor (each lead). And there is no solid ground plane as well. And PCB is located in a steel cage, so don't worry about electromagnetic emissions.
Offline ogden
  • Country: lv
« Reply #20 on: October 17, 2020, 05:49:44 pm »
Right. So what. I talk about prolonged leads/tracks between filter capacitor and DC bus, capacitor connected to DC bus "through extension cord". If this does not explain what I mean then just leave it there and we better end this fruitless chat.
So what. There is condcted emissions as well. If you do not filter hi-frequnecy ripple in DC bus, then wires going out of steel cage become antennas. Also downstream circuit my not like unfiltered ripple.
Offline wraper
  • Country: lv
« Reply #21 on: October 17, 2020, 06:03:01 pm »
Don't be ridiculous, additional centimeter or two from electrolytic capacitor leads will not make any significant difference in SMPS operating at about 30-60 kHz. It's not like extending leads of MLCC in a high frequency device. If you are so concerned about 20MHz, place 0.1uF MLCC with short leads in parallel  :palm: and it will have much lower impedance than electrolytic cap at such frequency.
Offline ogden
  • Country: lv
« Reply #22 on: October 17, 2020, 07:02:32 pm »
You need to learn, kid.
Offline wraper
  • Country: lv
« Reply #23 on: October 17, 2020, 07:48:09 pm »
You need to learn to be realistic grandpa. Suggesting general purpose caps in a place where they will certainly fail instead of LOW ESR on somewhat extended leads is lame. Not that he will bring that monitor to EMC certification to begin with. And apparently you have completely no idea about monitor SMPS and how stressed those caps are. They run damn hot and at high ripple current.
« Last Edit: October 17, 2020, 07:58:27 pm by wraper »
Offline bdunham7
« Reply #24 on: October 17, 2020, 08:35:15 pm »
Hi
I recently repaired my monitor power (brick) and had similar issues.  The original caps were made to fit tightly and just barely meet specs, so they cooked.  I was able to do a little grinding and make way for 35 volt caps, which were bit taller and had better ripple ratings.  I don't know if you have the room for that.
As for ESR and ripple...
Don't obsess about the ESR in particular,  instead try to find caps that have a ripple rating at least equal to the output current of the power supply circuit.  And parallel caps do add up, so if you sub in two 470uF for 1000uF, just multiply the ripple rating X2.  If you find caps that meet that requirement, the ESR is going to be fine--high ripple and low--or low enough--ESR ratings usually go together.  I would make specific suggestions, but I have no idea what your parts availability is there.  I'm sure it isn't easy.
