Author Topic: Can't find this IC, it's on MSI Optix AG32C PC Monitor  (Read 572 times)
Offline BC547BTopic starter
« on: April 20, 2024, 08:57:08 pm »
Hi, Has anyone seen this IC Before? The marking code on it is AEB it's 10 pin. Thank you.
Background:
- The problem with this monitor is that when you plug it via HDMI or DisplayPort, it says no signal.
- The problem begun with weird flicker happening every morning when I turn on the computer and then it stabilizes and works well. I don't have an image of this problem but I found someone that posted a picture of the same problem: https://ibb.co/NFs26D5
- Now it doesn't recognizes nor the DisplayPort nor HDMI. I haven't tried connecting via DVI yet, I've ordered an Adapter DVI to HDMI to see if it works.
- I've tested 90% percent of the components on the board. These little devils are what's left, I don't know what they are, I don't know what they do. I've attached a photo of them.
« Last Edit: April 20, 2024, 09:01:02 pm by BC547B »
Offline fzabkar
Re: Can't find this IC, it's on MSI Optix AG32C PC Monitor
« Reply #1 on: April 20, 2024, 09:12:10 pm »
It's probably a TVS diode array for ESD protection. You should be able to remove it without affecting the operation of the monitor.
Edit:
https://pl.aliexpress.com/item/1005005472090433.html
AEB = ESDU5V0AG4B
https://www.lcsc.com/datasheet/lcsc_datasheet_2203231830_Jiangsu-Changjing-Electronics-Technology-Co---Ltd--ESDU5V0AG4B_C2910045.pdf (datasheet)
« Last Edit: April 20, 2024, 09:20:03 pm by fzabkar »
The following users thanked this post: BC547B
