Author Topic: Can’t identify transistor  (Read 1597 times)
Offline sr77Topic starter
« on: January 27, 2020, 04:55:21 am »
Hello everybody, I’m trying to figure out what transistor i have so that i can find a datasheet and a replacement. The writing on it says:
M176
023
Any ideas? I appreciate the help.
Offline Nusa
Re: Can’t identify transistor
« Reply #1 on: January 27, 2020, 06:00:52 am »
You've left out too much that you can see, but we can't. We've no clue if you're looking at a big quarter-sized power transistor, a tiny smd device the size of a gnat, or anything in-between. And for that matter, are you even sure it's a transistor? Is there any labeling on the circuit board? What's the nature of the device it's in? Approximately how old is it? (That tells us what vintage the components are.)
I'd suggest a picture might be the easiest way to convey that information.
« Reply #2 on: January 27, 2020, 06:32:11 am »
It’s a b&k precision 290 multimeter. I’m guessing it’s from the 70s.
Offline Haenk
« Reply #3 on: January 27, 2020, 07:27:34 am »
Looks like "Motorola" - so that "M" is not a part number.
Here is a look at the schematics (at 25:30):
https://youtu.be/A0PDHj1O02I
Offline goaty
Offline shakalnokturn
« Reply #5 on: January 27, 2020, 09:13:15 am »
Haven't looked at the schematic, would MPSA76 fit?
Offline goaty
« Reply #6 on: January 27, 2020, 10:42:23 am »
I identified Q1 as SPS2306. (Found because of number 176-023-9-001)
Q2 is ddescribed as "blue dot", don´t know what that means.
Which is is Q1 or Q2 ?
« Last Edit: January 27, 2020, 10:44:42 am by goaty »
The following users thanked this post: sr77
Online Fraser
« Reply #7 on: January 27, 2020, 10:57:14 am »
In the ‘good old days’ I saw different colour dots on transistors indicating gain ranges. So you sometimes needed to fit a transistor with the same gain range when looking for a replacement. In some cases you had to ‘select on test’ and actually test a whole bunch of the same part number to find one that had the correct gain value ! Oh those were the days  ;D
Fraser
Offline TerminalJack505
« Reply #8 on: January 27, 2020, 05:15:55 pm »
According to that video, if the meter isn't working then be sure to check the bulb since it is wired in series with the the rest of the circuit.  Apparently they are using the bulb as a current limiter.
« Reply #9 on: January 27, 2020, 05:51:15 pm »
It's Q1.
« Reply #10 on: January 27, 2020, 05:57:20 pm »
The manual says "transistor silicon signal, NPN" followed by B&K part number 176-023-9-001.
Online andy3055
« Reply #11 on: January 27, 2020, 06:34:29 pm »
This is correct. See page 5 of this pdf: http://bee.mif.pg.gda.pl/ciasteczkowypotwor/B&K/501a.pdf
This site (https://www.weisd.com/products/678370-sps2306-nte-equivalent-nte123ap-npn-audio-transisto) lists it as equivalet to NTE123AP
« Reply #12 on: January 29, 2020, 07:50:17 am »
I just wanted to thank everyone for taking the time to help. Thanks and see you next time!
