Author Topic: [Solved] Cap leak cleaning?  (Read 2777 times)
Offline spilihpsTopic starter
« on: July 09, 2017, 02:15:41 pm »
Hello!
Iam currently replacing caps on an old Super Nintendo board. One of them have leaked.
It seems that it have gotten under the soldermask.
Now, what is the best method to make it stop eating the trace? Should i "remove" the solder mask over the affected area and clean it.
Please see the attached image..
Thanks!
« Last Edit: August 01, 2017, 05:56:57 pm by spilihps »
Online madires
  • A qualified hobbyist ;)
Re: Cap leak cleaning?
« Reply #1 on: July 09, 2017, 02:42:16 pm »
I'd try a glass fiber brush/pen and IPA. Use the brush gingerly.
« Reply #2 on: July 09, 2017, 06:22:28 pm »
Thanks for your reply!
That is for removing the soldermask?
Online madires
« Reply #3 on: July 09, 2017, 09:26:34 pm »
Yep, the brush for removing the soldermask and the IPA to remove the remaining mess.
« Last Edit: July 09, 2017, 09:28:15 pm by madires »
Offline WastelandTek
« Reply #4 on: July 09, 2017, 11:24:13 pm »
I find the mask flakes off pretty easily when it gets like that.  Post up pics once you have it clean so we can see how it came out.
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Offline Flappy
« Reply #5 on: July 10, 2017, 07:22:24 am »
I like to immerse, soak and gently scrub boards to make sure all traces of electrolyte are gone.  The solder mask in your photo looks like it will flake off easily.  Use an antistatic brush.
« Reply #6 on: July 13, 2017, 10:26:57 pm »
Thanks everyone!
Ive ordered a brush and Circuit works pen overcoat pen.
Will update the thread when work is done!
« Reply #7 on: July 16, 2017, 11:40:59 am »
So the glassfiber brush is great!
Ive cleaned as much as i dared. Some dark spots left under the microscope. But i dont want to eat on the trace.
Will have a go at some scrap boards with the overcoat-pen now and then Close this up.
So far:
« Reply #8 on: July 16, 2017, 03:46:58 pm »
looking good  :-+
« Reply #9 on: August 01, 2017, 05:56:29 pm »
Thanks!
Here is a final Picture of the repair.
All caps replaced and the unit works!
Thanks for all your help.
