Author Topic: capacitance and ESR for this capacitor?  (Read 2287 times)
Offline kgavionicsTopic starter
« on: May 31, 2017, 01:47:17 am »
Hi
Someone gave me away a 50inch plasma tv that doesn't turn on.i took it apart and i right away i noticed that there's two bulged caps 3300uF 100V.To be sure that the problem is coming from these caps i desoldered them and measured the capacitance and the ESR.
C was around 2750 uF for both ( which i found quite low even with 10% tolerance)
ESR was 0.13 ohm.
According to Esr table found on internet ESR should not exeed 0.1ohm for this type of capacitor.
My question: are these caps good or not?
thanks in advance
Offline ahbushnell
Re: capacitance and ESR for this capacitor?
« Reply #1 on: May 31, 2017, 02:57:08 am »
If they are venting gas they are dead.
How did you measure the ESR?
Andy
« Reply #2 on: May 31, 2017, 03:09:02 am »
Andy
thanx Andy
The only way to figure out if the capacitor is good is capacitance and ESR.
i measured ESR using a cheap Chinese component tester bought from ebay.
Offline ahbushnell
« Reply #3 on: May 31, 2017, 03:30:47 am »
I think it's bad.
Hook it up to a DC power supply and charge the capacitor.  Does it draw current?  Make sure the polarity is correct.
Andy
Offline bsalai
« Reply #4 on: May 31, 2017, 10:53:43 am »
I'd order some new ones. Bulging caps are so often the problem that it's worth a couple of dollars to replace them. I've fixed a few things this way.
Sent from my iPhone using Tapatalk
Brad, W2EK
Offline cnqhdszq
  • Country: cn
« Reply #5 on: June 01, 2017, 03:41:13 pm »
you  had better to test The capacitor with a LCR Bridge  .
Offline cnqhdszq
  • Country: cn
« Reply #6 on: June 01, 2017, 03:49:12 pm »
If It had gas leakage out before ,It must be bad now ,do not trust    the result of chinese tester.It just a toy
