Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Capacitor 2K 470 ELA, which ones can replace it?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Capacitor 2K 470 ELA, which ones can replace it? (Read 1807 times)
OverclockVintage
Contributor
Country:
on:
October 08, 2021, 07:04:36 pm »
Hi, i have here a notebook HP Pavillion g4 of which there is a swollen capacitor, it is this 2K 470 ELA, can it be replaced by a different one, which? or not? Thanks.
Logged
paul_g_787
Frequent Contributor
Country:
Re: Capacitor 2K 470 ELA, which ones can replace it?
Reply #1 on:
October 08, 2021, 08:18:56 pm »
I believe that is a 470µF capacitor.
You can replace it with another 470µF capacitor of the same or higher voltage rating.
Not sure about the ELA though. I am not familiar with that coding.
Could you perhaps upload a photo of it showing the markings?
Logged
OverclockVintage
OverclockVintage
Contributor
Country:
Reply #2 on:
October 08, 2021, 08:33:35 pm »
Sure, here it goes:
Logged
paul_g_787
Country:
Reply #3 on:
October 08, 2021, 08:53:48 pm »
I managed to find this:
https://electronics.stackexchange.com/questions/500183/aluminium-electrolytic-capacitor-information-top-marking-9h-100-ela
So I believe that the E indicates 25V and the LA is the manufacturer's series ID.
So you need a 470µF 25V Aluminium Electrolytic capacitor.
Maybe like this:
https://cpc.farnell.com/panasonic-electronic-components/eeefk1e471p/capacitor-case-g-470uf-25v/dp/CA07884
Although be sure to check the pin spacing and the diameter / height of the new capacitor to make sure it will fit in place.
Logged
OverclockVintage
OverclockVintage
Contributor
Country:
Reply #4 on:
October 08, 2021, 09:05:11 pm »
Thank you, i will do that, i think it will be easy to find.
Logged
paul_g_787
Country:
Reply #5 on:
October 13, 2021, 07:46:52 pm »
Remember, if you cannot get a 25V one you can use a higher voltage rating such as 35V or 63V (assuming it in not physically too large). It is only the max voltage rating.
Just don't connect it backwards (not that I have ever done that of course
Logged
OverclockVintage
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
