Author Topic: Need help repairing my fluke-124-scopemeter  (Read 866 times)
Offline MMMHANAFYTopic starter
  • Country: eg
« on: October 10, 2021, 01:07:47 pm »
Just bought fluke-124-scopemeter used as new still has the transparent sticker on screen
 I bought it with a really too much money for me the only problem was the battery has a little drain
so I was wondering if I can measure the cells by scop it self cause I didn't have a multimeter at that time ,
 once I contacted the com black lead to one of cells it turned off and never work again , I opened the device and followed the service manual but no result ,
the only result is the masking firmware work if I pressed right and up buttons ,I measured a lot of small components but seems fine
, I contacted fluke US but they told me that fluke 124 is no longer supported , If any body has any experience for such a problem please help me ..
« Last Edit: October 10, 2021, 01:58:15 pm by MMMHANAFY »
Offline abdulbadii
Re: Need help repairing my fluke-124-scopemeter
« Reply #1 on: October 11, 2021, 01:35:09 pm »
First, clarify or elaborate it
  • Country: eg
« Reply #2 on: October 12, 2021, 01:46:23 am »
I did it once before in a multi-meter it was fine , beside I was pretty sure that such a good brand like fluke should has a perfect protection like to isolated the battery power because they already use transformers inside like in the fly back converter and charging circuit..
« Last Edit: October 12, 2021, 10:00:04 am by MMMHANAFY »
Offline abdulbadii
« Reply #3 on: October 13, 2021, 10:48:12 pm »
have PC with Windows or Linux WIne installed?
install LTSpice
get https://drive.google.com/file/d/16RVgP5UDUI79lv17VLzlOSHrV9EOeX3f/view?usp=sharing
try as narrow as possible the most likely trouble
do schema of that and simulate it
