Hi all,
I forgot to edit the title.
I have some questions about multi-speed taps in a PSC single phase motor.
Please refer to the diagram
Questions
- i'm not sure if i understand this correct. If you select a medium speed, you are tapping into portion of the run coil that generates enough torque corresponding to the medium speed. This happens because the current enters the coil at a tap (much like a transformer winding) and proceeds through the rest of the circuit. what happens to the current that runs in the other direction, going through the coils that you are not using? Does that contribute to torque at all?
- does it matter which winding you tap into for the speed selection? for e.g., i see some tap the run winding, and others tap the start winding.
thank you
There is induced voltage, as well as some induced current, in the open section(s) of the main winding speed tap. However, for all intents and purposes this interaction is irrelevant, outside of engineering and design.
Does it matter which winding you tap into for the speed selection?
Yes and no... it depends. Your question lacks specifics in order to give a relevant answer.
I presume that the taps that you are referring to are the defined ones for motor usage. The connections to the motor are usually defined as High, Medium, (intermediate, if any), Low and common. Capacitor connection is usually a separate cable or separate wires, to avoid misconnection.
It is important to note that only one of the speed taps should be connected, or switched, to line at a time.
For example, L1 to one of the speed taps and L2 to common. If L1 were connected to more than one speed tap at the same time, then the motor would draw excessive current and would likely be damaged.
Often control circuits for these type of fan motors use SPDT relays for each speed. The NC contact of each relay would supply power to the next speed tap relay common. This is done so that if one relay were to fail (NO contact to speed tap stuck closed) then it would prevent more than one speed tap being powered simultaneously and damage to the motor.
