I'm replace a few capacitors from a bit of gear made (I think) in the 60s. However I'm having some uncertainties about certain capacitor values as I cannot find any schematics for this instrument on the internet (Advance Instruments TC9 B/S). Would anyone be able to check my assumptions for the following capacitors please?
The first is in series with the signal input - I'm guessing this is a 0.15uF 400V capacitor - but I'm not familiar enough with the different cap types to know if it is paper/polystyrene/whatever. What would be a good substitute here?
The second picture shows a large green capacitor on the main board for the nixie tubes. Initially I presumed this was a 4.7 mF capacitor (4700uF), but my LCR meter measured it as 4.9uF, so now I am assuming this is 4.7uF. I also assume this is for 160V, but please correct me if I'm wrong on this too.
Finally there is this arrangement on the mains input. I presume this is a 5000 pF capacitor - for 3000V? I'm not sure what the yellow component is - it has DCC TYPE 666 1 AMP 6937 written on it.
Here is the schematic of the two lots of this components - I presume it is a mains filters, so the yellow component is an inductor of sorts. Any idea for value?
