Hi
I want to build a capacitor leakage tester/ checker instead of buying something expensive.
I was thinking of using my variac, followed by a voltage doubler to reach about 700V DC.
I'm not sure how to do the metering. I could either use a 50uA moving meter in series with a 10k resistor followed by the cap under test, or I could measure the voltage across the cap instead of the uA meter keeping the series 10K resistor.
I'm open for ideas and if any one has a better layout, please share it with me.
Thank you!
