Hello!
So a friend asked me to have a look at his front drivers door ecu Before purchasinga new.
The fault:
The window motor only runs down. Everything else in the door works as expected.
I opened it up hoping for somekind of relay-issue. Found a "dual Power relay"(ACF231)
So i desoldered it from the board and tested it on the bench. Ofcourse it did work. Both "sides" of it.
However, i do remeber a board (totaly different application) that i was asked to replace a relay on. That relay also did work on the bench. But the board started working with the new. Have no idea if its possible for the relays to get "hung up" or something and maybe loosen up with desoldered from handling/heat.
I tested the components close to the coils of the relay, diodes and resistor networks (in Circuit) and they test fine. However, there is a IC (Q1) Close that does not have any markings on it. So no ideas yet.
Any input?
I add a Picture of the board, with the relay removed.
