Author Topic: car radio bulbs no longer working  (Read 407 times)
Offline BillStrachanTopic starter
« on: December 23, 2024, 11:35:13 pm »
i have a radio from a 06 silverado and i soldered in new led bulbs into the display and they shorted out when i plugged the radio back in. everything still functions but the lights are all out. i found that one of the bulb pins was protruding too far past the board and touched a backing plate which i believe grounded out causing all the bulbs to no longer turn on. i took apart the radio again and the bulbs still work when i put 12 volts to the display board separately. so something on the board got damaged and im curious if i can replace a component on the board rather than order a whole new used radio off ebay. i dont exactly know what to look for but i havent seen any burnt components on the board.
Offline Jeff eelcr
Re: car radio bulbs no longer working
« Reply #1 on: December 24, 2024, 01:45:42 am »
First check for blown fuse/s in vehicle if not any and problem is on main PCB track backwards from where you shorted it.
Look for open resistors/ transistors/ regulator IC's or what you could have damaged.
Jeff
Online CatalinaWOW
« Reply #2 on: December 24, 2024, 04:04:46 am »
Don't know about this radio, but in some the lights are on a different circuit than the radio itself.  So the radio may play with the lights out due to a car level fuse.
Offline Swake
« Reply #3 on: December 24, 2024, 08:48:39 am »
Back in the day the lights in a radio only came on when the lights of the car itself where on (dim or high beam). There was a separate wire for this.
When it fits stop using the hammer
« Reply #4 on: December 25, 2024, 02:15:49 pm »
Did you put resistors in series with the LEDs?
