Author Topic: car stereo not turning on  (Read 3342 times)
Offline PortoTopic starter
« on: January 15, 2015, 02:24:39 am »
Hello,
For 2 years already I have here a car stereo laying around which won't turn on anymore.
It's a 1-din, China made no-name thingy with a 7" foldable touch display, which in whole worked quite good!
The standby LED is lit when on 12v power but it won't go out of standby.
The switch itself is working.
Is this a classic case of a malfunctioned cap you think?
Thanks in advance.
Online wraper
  • Country: lv
Re: car stereo not turning on
« Reply #1 on: January 15, 2015, 03:10:06 am »
Rather dead flex. Capacitors do not die very often in such situation, this is not PC monitor. And not with such kind of defect.
« Reply #2 on: January 16, 2015, 04:55:49 am »
Thanks for the reply.
I haven't check the flex yet so I'll do that.  :-+
Offline aargee
« Reply #3 on: January 16, 2015, 05:14:22 am »
I know this is an obvious question but you do have both the main 12V (IGN) and the Acc 12V connected to 12V?
Not easy, not hard, just need to be incentivised.
Offline Psi
« Reply #4 on: January 16, 2015, 06:19:14 am »
Bad caps would definitely be something i would suspect.
I've seen brand new PC motherboards where all of the caps have leaked after being sit on the shelf for 6 months.  (zero use, just sitting on the shelf).
Really bad electrolytics will swell up and leak from ambient temp!!
« Last Edit: January 16, 2015, 06:21:18 am by Psi »
Offline Falcon69
« Reply #5 on: January 16, 2015, 06:31:08 am »
if it is an older model, you may need to connect the emergency brake wire.  The older models would not turn on the displays (for fear of operating a dvd movie in drivers view) in the US unless that wire was connected.  I can't remember if that wire needed to be grounded or a shift from ground o +12 volt pull-up, or just connected to +12v pull-up.  need to check the install instructions.
« Reply #6 on: January 16, 2015, 02:32:22 pm »
yes, both constant 12v and ignition 12v are connected. It didn't work one day in the car where it did work the day before.
After that I tried on the workbench with a 13.8v power supply but it just stays on standby.
It is not only the display which is not turning on, it's the whole radio.
Maybe the current is first supplying the display, via the flex, and than the tuner itself, so it already blocks at the
display not getting power?!
There are no eletrolytics in there, only SMD. It's not a very old radio, it has navi, BT, DVD etc
I just found a brandname, it's a Meos MC701B, year 2008... never heard of it though.
