Hi guys,
Long time reader first time poster etc etc...
My knowledge is pretty sparse but I'm confident when armed with a small amount of knowledge
Got a UTP video Tx/Rx (not IP/switched) set at work for sending VGA over large distances.
Had two of the Rx units fail - they're supposed to receive power over the UTP cable (direct from the Tx unit), but can take 12v separately; have tried and the LED doesn't light and video signal doesn't work under either condition.
I'd like to think it's as simple as a fuse on the board, but there's some components that I'm not sure how to identify.
Picture attached - the component in the bottom right does not have continuity - could this be it? The (assuming) fuse under the DC jack is fine, but I wouldn't expect this to have any impact on the standard power input anyway.
Any advice is appreciated; work can't afford to buy replacements for these as they're surprisingly expensive.
Cheers,
Ollie
