Some CB acts really erratic when PLL circuitry is compromised (i.e Not RF Power at output or not RX signal at all or combination of both).
Just repaired a Realistic TRC-429 One Handler (means all controls are in handset) from late 1970s, cousin of the following list : Cobra 19GTL, 19GTL AM/FM, 19LTD, 78X; Craig L103 ,G.E, 3-5804G, 5816, 5900A; President VEEP, AR-14, AX-14; Realistic TRC210. TRC411. TRC416; SBE LCM5; Sears 663,3802,38009;Teaberry Stalker IV, Statker VIII and Uniden PC 14.
Not much info for service manuals available for the TRC429 model and of course this presented a nice challenge as all functions seems to work and I was able to turn it ON and OFF from volume knob, view the channel number and choose for desired channel 1 to 40 on rotary selector, but Not sound, not transmitting not Squelch . Opened up shield cans showed a PLL MB8733 kind of similar to TC9109.
There is not much documentation on the MB8733 PLL other that is completely compatible with TC9109. Found some schematic for the realistic mobile TRC-411 which uses same MB8733 PLL. There is a lot of differences with TC9109; the Xtal circuitry is not external for the MB8733 and is internally controlled by pin 2 and 3, Pin 2 acting as source voltage for the oscillation and pin 3 the actual reference oscillation and to feed other circuits. Pin 14(Bin data) is not connected to "d" 7-segment, instead is connected to "b" segment and it cause all tables from TC9109 data to be a lot different (which almost get me going to reverse wires on Rotary Control). The R/T pin logic levels are inverted as well Rx being H and Tx being L. On some sort of frequency protection by internal ROM the PLL will not lock if any Data Line is missing or erroneous data or if VCO is out of frequency.
There I was trying to troubleshoot the PLL. Found Not oscillation on XTAL pin 2 and 3 (10.240Mhz), traced for shorting in capacitors or Variable cap and found nothing. One might think "BINGO" the Xtal is bad ( had never seen a dead Xtal). So, because I will CHANGE the xtal I need access to the soldering pads which was just underneath of another metal shielding covering the PLL and VCO circuitry on the soldering layer.
Then the culprit was found , the RF pickup transformer for the VCO had mostly invisible breaking cold joints caused by some accumulation of old soldering and little knocks and of course little vibration here and there. By re-soldering cold soldering pads the anomaly is gone and then Xtal begin to oscillate and the whole thing is fully operational on RX and there is 3 watts on TX.
Hope it helps for others and here the source of info I used
https://www.manuals.cornpone.net/Realistic/ ,
http://www.cbtricks.com/radios/teaberry/stalker_iv/graphics/teaberry_stalker_iv_viii_sm_pg10_22.pdf ,
https://www.fichier-pdf.fr/2017/07/06/pll-hb-1/Patty
PS. Sorry if I am on wrong post as newbie.
