Hi everyone,
I’m renting a place with furniture, including an LCD TV from 2012.
I got quite a good deal with the landlord so I’m trying to keep a good relationship and not to be picky. At the same time, I’m responsible for repairing or replacing anything that breaks during my stay.
On day #3 I turned the TV on for the first time and I found that half the screen was dim, so the first thing I thought was a burned out CCFL tube on the backlight. Was about to tell the landlord the next day. Then 40 minutes later the tube slowly started to brighten up and now it’s at mostly the same brightness as the other tube, also the same tone of color. Found it curious, because it’s now because it turned on so gradually… it didn’t seem like an intermittent connection to me. It’s probable that the TV has sat unused for 6 months. I did move it around a bit with the usual care one has for LCD panels.
Im both curious from the technical side and also for protecting my wallet and landlord relationship. Has anyone seen something like that happen before? Do you think it’s going to fail in the next 6-12 months?
