@Runco990: I agree, the single beam CDM-0 to CDM-4 are extremely reliable (CDM-4 probably the most) and problems can almost always be related to other causes, for instance wear on the clamp pivot point causing vibration, and also failure of the electrolytic on the current control signal to the base of the laser driver transistor. The main cause of actual laser failure is people misunderstanding the power adjustment and setting them to excessive current. Some service manuals warn against touching the laser current pot, as it is only supposed to be used for manufacturing / new transport installation. The pickups and decoders are very tolerant of any long term reduction in light output. Other things, like glass optics rather than plastic, not to mention the use of swing-arm radial tracking rather than motor and plastic cog linear tracking, are 'built to last' features of the early CDMs. They were probably the sweet spot in terms of semiconductor lasers having become reliable and later cost reductions.
I don't know if triple beam pickups need to work the laser harder, but once they became necessary for access speed in CDROM drives, they also became universal in audio players too. Again, triple beam technology require linear tracking (rather than radial) with guide rails and motor and cogs because of the beam shape. They also require a much more delicate lens assembly with more degrees of movement in the much smaller lens (fine side to side tracking and focus rather than just simple robust focusing), allowing more dust ingress and sensitivity. A few players were produced with linear voice coil tracking but I don't know if they have proved more reliable over the decades.
