CD Player - Musical Fidelity X-Ray
This is the problem on the surface, could this be the driver for the VFD causing a problem?
If so, is it possible that whatever the problem could be linked to the unpredictable jumping the player does when playing a CD?
The KSS-240A assembly has been replaced (which made it behave better but not cured).
The rails and guides have been dismantled, cleaned, re-greased and reassembled.
Or is it more likely that these two faults are unlinked.
Many thanks for any interest taken
