Author Topic: CEC DX51 digital to analog converter pops when music starts  (Read 159 times)
Offline penmarkerTopic starter
  • Country: my
« on: September 06, 2024, 10:06:57 am »
Hi everyone hope everyone is doing great.
I acquired this DAC and looking for a popping solution.
The right channel will pop whenever audio starts playing. It can be replicated by either play/pause or turning volume up from 0.
(Picture 1)
There are a pair of CHAMP Modules (red, horizontal with many LEDs) which I assumed was the cause. After swapping the cards the popping did not swap so it could be up stream.
The three boards (vertical) are Decoder board, Digital Filter board, and DAC board.
(Picture 2)
The dac uses 4 PCM1704 chips.
No service manuals are available and information is sparse.
The DAC board also has 2 kinds of tantalum caps. One is marked 47 10V. Another is marked 47 10g.
What does the g stand for?
Aside from the popping and slightly higher noise floor compared to modern DACs, it sounds good.
Need some help to nudge where I should start prodding.
Pop appears on both hot and cold out. RCA and XLR both pops
