Author Topic: ceramic resistor abbreviations  (Read 2356 times)
Offline jbombaTopic starter
« on: December 30, 2014, 07:51:42 am »
hi guys bit new to repairing pcbs. anyway ive got a ceramic resistor on a pcb that has spewed its guts on the pcb. Red crap everywhere. the abbreviation on the resistor is 5w22KRK. would i be correct to assume this is just 22k or does the rk afterwards mean something different?
Offline Christopher
Re: ceramic resistor abbreviations
« Reply #1 on: December 30, 2014, 08:05:16 am »
Yes replace it with a 5w rated 22k resistor,  you are right. The RK is probably gonna be tolerance information.
Offline Derresh
« Reply #2 on: January 01, 2015, 10:22:11 am »
R is the Multiplier Info, in this case its R means x1, dunno why they put both K for x1000 and R there... but well maybe they wanted to make it clear its a Resistor
the last K is indeed tolerance, stands for 10%
