This is my SRAM Tester made with an ArduinoMega 2560
Attached you will find the instruction to build it yourself and the Arduino Code.
I succesfully identified the IC that were failing on my modules, removed it from the ceramic substrate and restored one module out of 2!!!!
Now my Olivetti M10 is working fine with 2 SRAM modules.
Please let me know if you will find this usefull or if you have a better simpler method to identify the bad IC in a module (I tried using a TL866 programmer with no luck).
This tester is so flexible and it can be adapted to test several kind of IC
Hoping it will help someone, I made a separete thread:
https://www.eevblog.com/forum/repair/sram-tester-with-arduino-mega-for-retrocomputers/Mauro
Arduino Mega SRAM Tester for TRS-80 Model 100 , Olivetti M10 , Kyotronic KC-85 , NEC PC-8201A ...
Code:
// ArduinoMega SRAM Tester for
// TRS-80 Model 100 / Olivetti M10 / ...
// Author: Mauro Pintus
// Date : 2018 12 21
// Ver : 1.7
// ___________SRAM PINs___________
// | _MEGA GPIO_ | TOP View Bottom View
// | | | | _____U______ _____U______
// A07 [01] (D22) (+5V) [28] VCC | __u___ | .| ______ |.
// A06 [02] (D24) (D25) [27] A08 | | | | .| | | |.
// A05 [03] (D26) (D27) [26] A09 | | | | .| | | |.
// A04 [04] (D28) (D29) [25] _WE | | IC1 | | .| | IC4 | |.
// A03 [05] (D30) (D31) [24] CE4 | | | | .| | | |.
// A02 [06] (D32) (D33) [23] A10 | |______| | .| |__n___| |.
// A01 [07] (D34) (D35) [22] CEX | | .| |.
// A00 [08] (D36) (D37) [21] IO7 | __u___ | .| ______ |.
// IO0 [09] (D38) (D39) [20] IO6 | | | | .| | | |.
// IO1 [10] (D40) (D41) [19] IO5 | | | | .| | | |.
// IO2 [11] (D42) (D43) [18] IO4 | | IC2 | | .| | IC3 | |.
// GND [12] (---) (D45) [17] IO3 | | | | .| | | |.
// CE1 [13] (D46) (---) [16] GND | |______| | .| |__n___| |.
// CE2 [14] (D48) (D49) [15] CE3 |____________| .|____________|.
//If the test will FAIL some pin could be shorted to GND or to VCC
//so all pins will be set as input to prevent damage to the Arduino
//A small resistor (150 Ohm) between each Arduino GPIO and memory pin
//should prevent any damage to the Arduino.
#define pinCE1 46
#define pinCE2 48
#define pinCE3 49
#define pinCE4 31
#define pinCEX 35
#define pin_WE 29
#define pinA00 36
#define pinA01 34
#define pinA02 32
#define pinA03 30
#define pinA04 28
#define pinA05 26
#define pinA06 24
#define pinA07 22
#define pinA08 25
#define pinA09 27
#define pinA10 33
#define pinIO0 38
#define pinIO1 40
#define pinIO2 42
#define pinIO3 45
#define pinIO4 43
#define pinIO5 41
#define pinIO6 39
#define pinIO7 37
#define max_addr 0x7ff
// Configuration variables
// Fill = 0 the tester will read the memory without writing on it
// Fill = 1 the tester will test each cell of the memory
int Fill = 1;
// Verb = 0 the tester will print only the test results
// Verb = 1 the tester will print on the serial port all the memory content
int Verb = 1;
uint8_t ctrl_pins[] = { pinCE1, pinCE2, pinCE3, pinCE4, pinCEX, pin_WE };
uint8_t addr_pins[] = { pinA00, pinA01, pinA02, pinA03, pinA04, pinA05,
pinA06, pinA07, pinA08, pinA09, pinA10 };
uint8_t inout_pins[] = { pinIO0, pinIO1, pinIO2, pinIO3,
pinIO4, pinIO5, pinIO6, pinIO7 };
int failed = 0;
int PassFail[]= {0,0,0,0};
void setup()
Serial.begin(115200);
Serial.println(F("\n*****************************************"));
Serial.println(F("ArduinoMega SRAM Tester for"));
Serial.println(F("TRS-80 Model 100 / Olivetti M10 / ..."));
Serial.println(F("Author: Mauro Pintus"));
Serial.println(F("Date : 2018 12 21"));
Serial.println(F("Ver : 1.7"));
Serial.println(F("*****************************************\n"));
Serial.println(F(" ___________SRAM PINs___________ "));
Serial.println(F(" | |"));
Serial.println(F(" | _MEGA GPIO_ | TOP View Bottom View "));
Serial.println(F(" | | | | _____U______ _____U______ "));
Serial.println(F("A07 [01] (D22) (+5V) [28] VCC | __u___ | .| ______ |."));
Serial.println(F("A06 [02] (D24) (D25) [27] A08 | | | | .| | | |."));
Serial.println(F("A05 [03] (D26) (D27) [26] A09 | | | | .| | | |."));
Serial.println(F("A04 [04] (D28) (D29) [25] _WE | | IC1 | | .| | IC3 | |."));
Serial.println(F("A03 [05] (D30) (D31) [24] CE4 | | | | .| | | |."));
Serial.println(F("A02 [06] (D32) (D33) [23] A10 | |______| | .| |__n___| |."));
Serial.println(F("A01 [07] (D34) (D35) [22] CEX | | .| |."));
Serial.println(F("A00 [08] (D36) (D37) [21] IO7 | __u___ | .| ______ |."));
Serial.println(F("IO0 [09] (D38) (D39) [20] IO6 | | | | .| | | |."));
Serial.println(F("IO1 [10] (D40) (D41) [19] IO5 | | | | .| | | |."));
Serial.println(F("IO2 [11] (D42) (D43) [18] IO4 | | IC2 | | .| | IC4 | |."));
Serial.println(F("GND [12] (---) (D45) [17] IO3 | | | | .| | | |."));
Serial.println(F("CE1 [13] (D46) (---) [16] GND | |______| | .| |__n___| |."));
Serial.println(F("CE2 [14] (D48) (D49) [15] CE3 |____________| .|____________|."));
Serial.println();
void checkPins()
int readback,index,i;
String text;
for (index = 0; index <= 1; index++)
if (index == 0) text="HIGH "; else text="LOW ";
for (i = 0; i < sizeof(ctrl_pins); i++)
if (index == 0) pinMode(ctrl_pins[i], INPUT_PULLUP);
else { pinMode(ctrl_pins[i], OUTPUT);
digitalWrite(ctrl_pins[i], LOW);
readback = digitalRead(ctrl_pins[i]);
if (readback != index) {
if (Verb==1) Serial.println("Check: Ctrl pin " + String(i, DEC) + " " + text +"PASS");
digitalWrite(ctrl_pins[i], HIGH);
} else {
if (Verb==1) Serial.println("Check: Ctrl pin " + String(i, DEC) + " " + text +"FAIL");
pinMode(ctrl_pins[i], INPUT);
failed++;
if (Verb==1) Serial.println();
//set address pins as output
for (i = 0; i < sizeof(addr_pins); i++)
if (index == 0) pinMode(addr_pins[i], INPUT_PULLUP);
else { pinMode(addr_pins[i], OUTPUT);
digitalWrite(addr_pins[i], LOW);
if (Verb==1){
if (i<10)Serial.println("Check: Addr pin " + String(i, DEC) + " " + text +"PASS");
else Serial.println("Check: Addr pin " + String(i, DEC) + " " + text +"PASS");
} else {
if (Verb==1){
if (i<10)Serial.println("Check: Addr pin " + String(i, DEC) + " " + text +"FAIL");
else Serial.println("Check: Addr pin " + String(i, DEC) + " " + text +"FAIL");
pinMode(addr_pins[i], INPUT);
failed++;
//set I/O pins as input
for (i = 0; i < sizeof(inout_pins); i++)
if (index == 0) pinMode(inout_pins[i], INPUT_PULLUP);
else { pinMode(inout_pins[i], OUTPUT);
digitalWrite(inout_pins[i], LOW);
if (Verb==1)Serial.println("Check: I/O pin " + String(i, DEC) + " " + text +"PASS");
} else {
if (Verb==1)Serial.println("Check: I/O pin " + String(i, DEC) + " " + text +"FAIL");
pinMode(inout_pins[i], INPUT);
failed++;
if (Verb==0)
if (failed == 0) Serial.println(F("Check pins PASS\n"));
else Serial.println(F("Check pins FAIL\n"));
void setAddress(int address)
for (int i = 0; i < sizeof(addr_pins); i++)
digitalWrite(addr_pins[i], ((address >> i) & 1));
void writeData(uint8_t data, int IC)
int pinCEn;
switch (IC) {
case 1:
pinCEn=pinCE1;
break;
case 2:
pinCEn=pinCE2;
break;
case 3:
pinCEn=pinCE3;
break;
case 4:
pinCEn=pinCE4;
break;
digitalWrite(pin_WE, LOW);
digitalWrite(pinCEn, LOW);
digitalWrite(pinCEX, LOW);
for (int i = 0; i < sizeof(inout_pins); i++)
digitalWrite(inout_pins[i], ((data >> i) & 1));
digitalWrite(pin_WE, HIGH);
digitalWrite(pinCEn, HIGH);
digitalWrite(pinCEX, HIGH);
int readData(int IC)
int pinCEn;
switch (IC) {
case 1:
pinCEn=pinCE1;
break;
case 2:
pinCEn=pinCE2;
break;
case 3:
pinCEn=pinCE3;
break;
case 4:
pinCEn=pinCE4;
break;
delayMicroseconds(1);
uint8_t readback=0;
readback = readback | ((digitalRead(inout_pins[i]) << i));
return readback;
void test(int Fill, int Verb)
if (Fill==0) Serial.println(F("Dump Entire Memory without writing on it"));
else Serial.println(F("Test Entire Memory"));
int Addr,index;
uint8_t Data[]={0x55,0xAA}; //Data Fill 01010101,10101010
uint8_t readback;
int tab=0;
int IC;
PassFail[0] = 1;
PassFail[1] = 1;
PassFail[2] = 1;
PassFail[3] = 1;
for (IC=1; IC <= 4; IC++){
for (index=0; index <= 1; index++){
if ((Fill==0)&&(index==1)) break;
Serial.print("IC"+String(IC)+" Content");
if (Fill==1) Serial.println(" after filling it with 0x" + String(Data[index],HEX));
else Serial.println();
for (Addr=0; Addr <= max_addr; Addr++)
if((tab==0)&&(Verb==1)){
if(Addr<=0xF) Serial.print("00");
else if(Addr<=0xFF) Serial.print("0");
Serial.print(Addr,HEX);
Serial.print(" ");
setAddress(Addr);
if (Fill==1) writeData(Data[index],IC);
readback = readData(IC);
if ((Fill==1)&&(Verb==1)){
if (readback == Data[index]) Serial.print(" ");
else
Serial.print("x");
failed++;
PassFail[IC-1]=0;
else if ((Fill==1)&&(Verb==0)){
if (readback != Data[index])
failed++;
PassFail[IC-1]=0;
else if ((Fill==0)&&(Verb==1)) Serial.print(" ");
if (Verb==1){
if(readback<=0xF) Serial.print("0");
Serial.print(readback,HEX);
tab++;
if(tab==32){
tab=0;
Serial.println();
if (Verb==0) Serial.println();
void loop()
checkPins();
if (failed == 0)
digitalWrite(LED_BUILTIN, HIGH);
unsigned long duration = millis();
test(Fill,Verb);
duration = millis() - duration;
Serial.println("Duration: " + String(duration/1000, DEC)+"S");
for (int IC=1; IC <= 4; IC++){
if (PassFail[IC-1]) Serial.println("IC"+String(IC)+" PASS");
else Serial.println("IC"+String(IC)+" FAIL");
if (failed > 0)
Serial.println("Result: FAIL (" + String(failed, DEC) + ")");
digitalWrite(LED_BUILTIN, LOW);
else
Serial.println("Result: PASS");
while(1);
