Thanks. So, what they say is the standard fine print because they have to do that to cover themselves. The primary winding is as I expected and you don't need to lift the board unless you cannot lift the link from the top and move it to 120 Setting. However, they don't seem to mention the glass fuse on the right. You have to put in the correctly rated fuse there because it has to go up in value according to the print on the board. The lower rated fuse for 240 volts will blow on 120 volts.
Like they say, you can attach a label on the power cord to confirm the it has been changed to 120 v.
Good luck
P.S. Make sure you pull the plug out before anything is done. It is easy to forget
