Author Topic: Siglent SDS1104x-e stuck at boot routine (SOLVED)  (Read 1886 times)
Offline little_carlosTopic starter
« on: March 22, 2022, 08:48:51 pm »
Hello everyone.
I own a Siglent SDS1104x-e which has been working ok for 3 years, bought it new.
Today, suddenly, it stopped working. It's stuck at the booting routine, here's what it does:
- Fan turns on
- Power button turns on
- Internal relay turning on and off
- screen shows nothing
- Rest of the buttons lights on
Already solved, here's the solution:
The firmware was never updated. So this is most probably an old firmware bug.
I had to start the scope with both channel 1 and channel 2 probes connected to the cal pin. This way for some reason started.
After that , updated to the newest firmware available and problem solved.
If any of you guys is thinking on buying a siglent scope, update the firmware as soon as new ver. are available
« Last Edit: March 22, 2022, 09:35:45 pm by little_carlos »
The following users thanked this post: fzabkar
Re: Siglent SDS1104x-e stuck at boot routine (SOLVED)
« Reply #1 on: March 23, 2022, 09:40:04 am »
Hello everyone.
- Fan turns on
Yes partially older FW is to blame however pressing Math, Math, Math fast and continuously at boot should get you past a boot freeze in these models.
For the latest FW update there is also an OSV2 update that enables the new NTP feature.
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1xx4X-E_V6.1.37R8_EN.zip
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1xx4X-E_OSV2_EN.zip
The OS update must be installed from the root of a USB stick and auto installs at boot.
The order of install doesn't matter.
Remember to delete the OS from the USB stick or it will run at each boot.
« Reply #2 on: March 23, 2022, 03:13:42 pm »
Thanks, ive already updated both Firmware and OS.
However, I did try the pressing math button quickly, but did not solved the issue
Offline bdunham7
« Reply #3 on: March 23, 2022, 03:17:00 pm »
Where did you get the idea to do that?
« Reply #4 on: March 23, 2022, 03:49:33 pm »
It thought that maybe internal calibration was failing, that's why I tried it. Not sure of why it did worked
« Reply #5 on: March 23, 2022, 07:09:22 pm »
Sometimes Math doesn't work first time and it normally pays to try it a few times as it's the normal fix for a boot freeze however Siglent do have a USB recovery package for theses scopes when Math doesn't work.
« Reply #6 on: March 24, 2022, 05:16:40 pm »
Thanks for the advice! Didnt knew about the USB recovery package, much appreciated!  ;D
Offline JFunc
« Reply #7 on: December 12, 2022, 02:01:15 pm »
I have the same issue here. The USB recovery package - is it downloadable directly, or do we have to contact Siglent? I have tried a blank USB stick with the firmware on it, but it's still stuck at the 'Siglent' boot image, no matter what I try...
« Reply #8 on: December 12, 2022, 07:26:55 pm »
Welcome to the forum.
Have you used the Math, Math, Math button procedure when booting the DSO ?
We try this several times and quickly before trying further recovery methods.
Offline JFunc
« Reply #9 on: December 13, 2022, 11:59:43 am »
Thanks for the reply!
Yeah - I've tried it numerous times, with no luck. It's a complete PITA, as I have a number of repairs piling up. Short of buying a new scope, is there anything else I can try?
« Reply #10 on: December 13, 2022, 08:04:15 pm »
Yep, we have tools to fix this.
Contact me via PM with your email and we'll have this sorted in no time.  :)
Offline JFunc
« Reply #11 on: December 16, 2022, 10:22:52 am »
Hi tautech!
I received a lovely email from Tom at Siglent UK, who gave me a package to try, and it worked like a dream. Thanks for the help folks. It's groups like these that restore your faith in humanity!
Have a great holiday season chaps and chapesses!
Andy.
« Reply #12 on: December 16, 2022, 10:44:37 am »
Hi tautech!
Andy.
Always best if you can get local assistance and build a working relationship with them.
Enjoy !
