So I am working on a Ford Body Control Module. The vehicle was in an accident and wire harness was smashed so some shorts occurred. the ECM also took a hit to the 5V power supply chip for the sensors but I was able to find and replace that chip. Now I have issues with the BCM. The rear hatch will not open for any reason and per the vehicle schematics, the latch relay is driven by the chip I linked. As was my 5V ECM chip, this one seems rather well protected BUT there is some indication that reversed polarity could damage the chip so there is a diode and resistor to ground.
I have found the chip on the BCM board and already desoldered it via hot air but the main issue is although I have found the pin on the MCU that drives the chip, I cannot find the ground at all! As you can imagine, these boards are production, 1x use kinda thing. Throw aways. So they were not really meant to be repaired. There are hundreds of vias and this is a tri-level board. I see the ground going to a 10K resistor, then looping back to the CS-DIS and that trace pops into the center layer with a via and I have no idea where it surfaces! I have spent hours testing everything and almost convinced at this point the trace may be burned BUT when I throw the meter in auto ohms, it seems to talk to several things from 10-100K ohms. If the trace was really blown, would it show up somehow visually?
I started combing the board for anything resembling a diode as I am expecting to find a diode and resistor to ground. At this point I cannot even determine what ground is! It is a complex critter!
