The vertical-noise lines and flickering on the right side is gone!🎉
Because i received the replacement 5V 40A power supply, so i opened it up to panel,
set up the full white test-pattern, i measured 4.95 voltage on both power supplies.
wanted to connect both 5V supplies to scope to see if they show the same pattern, but
i found some metalic debris parts inside the panel😲 got rid of it.
(Oh. The 220 power cord was connected to the 1st power supply. And a cable looped to the 2nd power supply, but was connected wrong-way ruound to the 2nd power supply. So i corrected it.)
Then i set up the white text,
and now the vertical noise patterns in the right side is not there.
So i think either it was debris, or the power cord to the second panel didn't have a solid connection.
Now i guess i've a new 5v power supply left over
