I found a Dyson V6 (DC58-DC62) vacuum cleaner in a dumpster.
![[solved] Dyson V6 (DC58-DC62) vacuum cleaner - motor running pulsed](https://www.eevblog.com/forum/index.php?action=dlattach;topic=412528.0;attach=1992133;image)
It is not complete - battery, air hose, nozzles, charger missing.
I found out, what battery voltage and polarity is needed and hooked the motor pcb up to my lab power supply (24V/6A).
The motor is not running continuously, it is just pulsed (about 3 bursts per sec).
I found some reports in the net regarding pulsed motor run - root cause always was blocked air flow (filter).
But that is not the case for this one, because I removed everything but the motor and the motor PCB.
As I said, the motor is turning for a few 1/10 s, stops and repeat this cycle about 3 times per second.
![[solved] Dyson V6 (DC58-DC62) vacuum cleaner - motor running pulsed](https://www.eevblog.com/forum/index.php?action=dlattach;topic=412528.0;attach=1992157;image)
Has anybody heard of the motor pulsing caused by another cause than blocked air flow?
Maybe over current? Or incorrect over current detection on the board? My supply can just deliver 6A, may be not enough?
PS: I added some pics I found in the net...
