Author Topic: [REPAIRED] Cheap 150W 48V SMPS repair (clicking noise)  (Read 9084 times)
Offline Richard Head
Re: Cheap 150W 48V SMPS repair (clicking noise)
« Reply #25 on: November 12, 2016, 11:15:42 am »
Power the control IC from a separate bench power supply and measure its gate drive output.The bench PSU obviously has to be isolated! You will probably find that as soon as you provide external power to the chip that the PSU works perfectly. If that is the case then disconnect the external bench supply DC and measure the signal from the feedback winding when the unit is clicking. There should be a string of pulses from the feedback winding that is able to charge the bleed-on cap and power the chip.
Offline dominicM
  • Country: ie
    • DominicM
« Reply #26 on: November 12, 2016, 01:22:35 pm »
Did you also check the 48V output for a short circuit? There can be can be other reasons like an open circuit in the secondary circuit.
There are no shorts between any output terminals.
Offline dominicM
  • Country: ie
    • DominicM
« Reply #27 on: November 12, 2016, 01:23:53 pm »
It is also possible to have shorted windings in the transformer. This can be difficult to prove.
Seems kind of unlikely to me for it to happen to 2 psu's though, no?
Offline dominicM
  • Country: ie
    • DominicM
« Reply #28 on: November 12, 2016, 01:26:17 pm »
Replace D2
No change, what was the reason for this suggestion specifically?
Do not replace this one by a "normal" diode. You need to use a ultra fast recovery type in many circuit to work correctly. Also ensure is has a high enough reverse breakdown voltage. I had 2 SMPSes failing because the diode reverse breakdownvoltage was serverly limited (got to hot probably), but measured still ok with a multimeter.
Some more info which type to select can be found here (altough I just picked one I had lying around from a previous project):
https://www.maximintegrated.com/en/app-notes/index.mvp/id/849
I replaced it with a working one from a similar 24V psu and there was no change, 24v worked while 48. clicked as before with D2 swapped out.
Offline dominicM
  • Country: ie
    • DominicM
« Reply #29 on: November 12, 2016, 01:52:32 pm »
Is U2 LM431? Can you swap it with a good one?
U2 is a TL431A. After swapping it works! So what was the logic behind this suggestion? The question now is why did it fail, it happened to 2 psus so I doubt it's just chance.
Looking at the datasheet it seem like it's only rated up to 36V, am I missing something or is it a design flaw?
« Last Edit: November 12, 2016, 02:11:22 pm by dominicM »
Offline strawberry
  • Country: lv
« Reply #30 on: November 12, 2016, 02:51:27 pm »
OB2269
Offline kxenos
  • Country: gr
« Reply #31 on: November 12, 2016, 04:19:37 pm »
No flaw. The 431 is probably in series with a resistor and optocoupler's LED.
You said that after removing power the PS continued to make the noise for a while so there was no short-circuit in the output. So the next reason for the PS not to be able to start is if there is a problem in the feedback circuit. I looked at the photo and I saw a TO92 in the secondary side. This is a classic configuration and a classic problem in cheap PSUs. Probably it will be OK if you install a genuine part. If there are problems in the future again you will have to add a snubber RC parallel to the 431.
Offline Bondguy
« Reply #32 on: November 12, 2016, 05:19:07 pm »
@Richard Head: it is an interesting idea but what will be tested that way? feedback winding of primary transformer or control IC?
Am I correct to think that by feedback winding you mean one of the primary winding that provides voltage for control IC when the power supply capacitor of control IC is being discharged?
Offline dominicM
  • Country: ie
    • DominicM
« Reply #33 on: November 12, 2016, 09:18:52 pm »
Will get some from rs. Out of curiosity is it safe to assume that most parts like this one from china on ebay are fake?
Would modifying the 24v ps to output 5v be feasible? It seems like it should be possible by changing resistors close to the 431. Don't want to blow it up just after repair :)
Offline xavier60
« Reply #34 on: November 12, 2016, 10:04:59 pm »
The output should have been pulsing up to about 1 volt during the clicks with the faulty TL431.
Reducing the regulation voltage would also reduce the supply voltage to the control IC which would cause it to repeatedly shut down after it starts in this case.
It would work in some designs where the IC is powered from somewhere else and not affected by the regulation voltage.
Hioki AS100D vom, HP 54645A dso, Fluke 87V dmm, AN8008 dmm, Agilent U8002A psu,  FY6600 function gen, New! Brymen BM857S-(With Battery)
Offline kxenos
  • Country: gr
« Reply #35 on: November 12, 2016, 10:14:01 pm »
I don't know about ebay parts because I have never bought any but I guess if it's too good to be true it probably isn't. When you repair or build something you try to minimize uncertainty factors, so buying parts from well-known distributors ends up being cheaper IMO.
About changing the output voltage, I'm sure you can. You will have to DaveCAD the secondary circuit around the 431 and replace a couple of resistors and maybe the output caps. The idea is that the output voltage controls the brightness of the optocoupler's LED. You will have to change the resistor values so that the LED has the same brightness (current through it)
Offline dominicM
  • Country: ie
    • DominicM
« Reply #36 on: November 18, 2016, 07:28:44 pm »
Well I did see a similar mod by someone somewhere and it worked fine, so it is feasible. In that case it was only maybe 10v lower than original supply so 24v to 5v may be bit too far. That being said 48v and 24v supplies look almost identical even most parts are identical or very close to.
Offline dominicM
  • Country: ie
    • DominicM
« Reply #37 on: November 18, 2016, 08:08:58 pm »
Got the parts but I think I may have gotten the wrong part. I ordered TL431C without really paying attention but the one in the PSU was TL431A. After replacing the clicking was still present though different sound. I can't really see the difference in the datasheet for these parts. What is the difference?
Offline kxenos
  • Country: gr
« Reply #38 on: November 18, 2016, 09:49:00 pm »
The difference is precision 1% for the A part vs 2% for the part you've got and also smaller operating temp. I don't think it matters much. Can you check the resistors around the 431 and install back the 431A part from the other PS and see what happens? Also can you place a small load in the output? Something like a 330 resistor
The following users thanked this post: dominicM
Offline dominicM
  • Country: ie
    • DominicM
« Reply #39 on: November 19, 2016, 10:15:05 pm »
I replaced the TL431 with the original and it was the same thing. The new TL431 worked fine in 24v psu so the new part is fine. The 330 resistor made no difference. I remembered that I dropped one of the boards and after close examination 2 pins of D3 have snapped  :palm: An easy fix if nothing else is damaged.
Offline dominicM
  • Country: ie
    • DominicM
« Reply #40 on: January 05, 2017, 12:47:22 pm »
Just to say all the PSU's are repaired and 1 of them has been working for quite a while now so it seems the repair was completely successful!
Offline SoundTech-LG
Re: [REPAIRED] Cheap 150W 48V SMPS repair (clicking noise)
« Reply #41 on: January 06, 2017, 05:53:23 pm »
That LM341 voltage reference could also be a (cheaper) Korean version KIA2431. Just saw that one in my Denon AVR-3312 SMPS...
