Hello,
I have one of those cheap 24V switch mode power supplies in use for the LED lighting, it has been running 2 years but now it has come near to it's end.
The big output coil started overheating, the output is fluctuating between 23-28V, caps look all good.
Can anyone point me in the right direction?
It's a bit hard to see in the pictures due to the light; under the coil the PCB has discolored because of the extreme heat.
Update:
Found this schematic online of a similar power supply and it doesn't make any sense to me how the coil can overheat that much...
