Author Topic: Cheap chinise buck converter power supply odd failure  (Read 929 times)
Offline justin66Topic starter
« on: October 01, 2020, 08:20:12 pm »
Hello guys, i have bought cheap buck converter cc cv module. It failed on me after a couple.of short circuit tests. It came out to be choke short. I fixed it. For temporary use i fited irf50n06 transistors, the power supply was fine and managed to withstand many short circuit tests. So i decided to put very good, low rdson transistors irfb3077. The first short circuit test and the main buck converter chip blown xl7005, should i try fixing it again? Or is this module is just crappy design? It says it has over current protection.
€ 15,33  5%OFF | WZ5020L WZ5012L DC DC Buck Converter CC CV Step-down Power Module 50V 20A 1000W Adjustable Voltage Regulated power supply
https://a.aliexpress.com/_mOyQgkX
« Last Edit: October 01, 2020, 09:11:06 pm by justin66 »
Offline thm_w
  • Non-expert
Re: Cheap chinise buck converter power supply odd failure
« Reply #1 on: October 01, 2020, 10:17:23 pm »
Did you remove that capacitor on the left side?
They say it has overcurrent protection but they don't specifically mention output short circuit protection. Its possible if its using software control to limit the current, a short could still cause damage, vs a slight overcurrent condition.
