I just wanted to comment on the use of a Huntron Tracker 2000.
I repaired a front panel board out of a Tektronix TDS420 oscilloscope two years ago. It needed new capacitors and the traces needed to be repaired due to the leaking electrolyte. I didn't test it since it was just practice. Since then, I came across another front panel board that worked perfectly after just replacing the caps. Both boards share the same part number and revision number:
Last year, a retiree gave me his old test equipment which included a Huntron Tracker 2000. Tonight, I broke out the Huntron and read the manual relating to "comparing."
I set both front panel boards up and connected the common lead to the (-) leg of the same capacitor on each board. I set the Huntron to alternate channels A & B, set the range to Med 1, and frequency to to 2000:
I was absolutely blown away as to how well it worked!
The Huntron probe tips are like needles. If you touch something it feels like it stuck to it!
I quickly touched and compared every component and pass-through on both sides of the boards.
You can adjust the speed of how fast the scope alternates plus select one channel to quickly touch several points that look like grounds or if they were all capacitors, etc.
Since most Tektronix oscilloscopes of that era don't have schematics, this tool is a dream come true to quickly check your repairs by comparing your work to a good board.
Here's a couple things that I noticed. If you touch an LED, it fires it! If you touch a terminal of a buzzer, it sets it off! I was able to compare the difference of the "tone" from the buzzers on each board!
I read in the manual, that when checking IC's, the signatures may be slightly different if they are from different manufacturers or lots. Here is an example of pin "5" of a TL074BC from each board (both are in the same location). Unless you guys think otherwise and feel that these should look identical? This also could be due to having the "range" set too low?
Anyway, what an awesome tool, and especially when used to repair these Tek scopes!
I'm finishing up on an attenuator board which I'll compare with a good one before I spend the time to install it
