Author Topic: Chinese plasma cutter/tig welder only getting a spark!  (Read 659 times)
Offline RaylickerTopic starter
« on: July 05, 2020, 11:22:29 am »
Hi all, I have an Accurate Tools plasma cutter/tig welder that was working fine. I went to use it the other day and now only getting a slight spark from the gun, also getting a little shock from case.. Getting arc on those two poles inside and don't see any burnt or anything abnormal inside. Attached are some pics of it.  Please anyone some help. Thanks for reading this.https://www.eevblog.com/forum/Smileys/default/scared.gif
Offline EPTech
    • EP Technical Services
Re: Chinese plasma cutter/tig welder only getting a spark!
« Reply #1 on: July 05, 2020, 02:21:20 pm »
Hi there,
Sounds like the HF pilot arc is working but you do not get the main arc. Many things can cause this. Blown rectifier diodes are the most common.
Try measuring the voltage on the secondary side, while pressing the trigger. Do not measure at the torch or anywhere between the torch and the choke as this will possibly ruine your meter.
You should measure around 70V open circuit. Depends from welder to welder. It wil drop conciderably once you establish an arc.
Be carefull. You are measuring on a high engergy circuit. I advise using clamps to probe what you want to probe, then power on the unit, operate it, and then measure.
Good luck.
Kind greetings,
Pascal.
Offline trevatxtal
« Reply #2 on: July 05, 2020, 03:13:54 pm »
Check the relays, common fail point.
Watch them when you press the trigger.
